LotharKrepke
- Joined
- Feb 1, 2009
- Messages
- 6
Howdy,
I have a Kubota B2772 snow thrower mounted on my B2710, and I am having an odd problem:
On one side, the auger shear pin is missing, but the auger is fixed to the drive shaft just as it would be if the pin were in place. The drive shaft is clean, and well greased. There is no rust.
I can use the thrower in this condition, but I hesitate to do it because I don't want to risk scoring the drive shaft. I can't install a new pin because I am unable to move the outer sleeve in relation to the inner shaft, and right now, the hole for the pin is nowhere to be seen.
My guess is that the pin broke, but some pieces of it got jammed between the auger sleeve, and the interior shaft.
In any case, I would value suggestions about how to proceed. I suppose that I could disassemble that part of the thrower, and then drive the interior shaft out, but there might be a better approach.
Thanks for any help on this,
Lothar
Lothar
