Results 1 to 1 of 1
03-30-2013, 06:43 PM #1New Member
- Join Date
- Oct 2012
- Posts
- 1
- Location
- Celina, Tn
- Tractor
- Kubota L4400, Ferguson TO-35, Ford 8N, John Deere 750, Kubota B7100, Kubota G6200
1984 John Deere 750 Lost Power Steering
Has anyone had experience troubleshooting the power steering on an Older JD 750 or 650? This PS system uses the same source of hydraulic pressure as the FEL through a priority valve. My FEL works fine, just no Power Steering. Two components might be the source problem, the directional valve which senses direction of the steering wheel or the cylinder itself. Priority valve seems to function as I'm getting pressure to the directional valve. I hadn't gone any further for getting soaked with hydraulic fluid and no one around to assist me as I troubleshoot. Seems this was a bad design and only used a couple of years as parts from the JD dealers are no longer available. I was hoping someone out there might know of the common problem that made JD change their design and lead me to the bad section w/o tearing everything down.
03-30-2013 06:43 PM # ADS
Similar Threads
John Deere 4110 power steering cylinder
By Mike Dermott in forum Parts/RepairsReplies: 3Last Post: 07-21-2012, 04:54 PM -
1977 John Deere 24-A skid steer lost power
By JimmyinMINN in forum Parts/RepairsReplies: 2Last Post: 04-05-2012, 11:19 PM -
John deere 750 Adding remotes without (power beyond kit)
By deere750man in forum Parts/RepairsReplies: 1Last Post: 07-18-2009, 06:16 PM -
John deere 425 power steering
By Oldmustang in forum Build-It YourselfReplies: 1Last Post: 11-24-2008, 11:50 PM -
By Oldmustang in forum HydraulicsReplies: 0Last Post: 11-22-2008, 02:44 PM
