Results 1 to 3 of 3
  1. #1
    Member
    Join Date
    May 2012
    Posts
    28
    Wattsburg Pa
    1940s mccormick deering 0-4, 170 allis chalmer, 950 john deere, 7030 and 7040 allis chalmer 986 international
    Default 7030 allis chalmer injectors
    hello i am trying to pull out injectors out of my 7030 allis chalmer and they just dont want to come out. i tried a slide hammer and dint budge them so tried a pry bar nothing, than last night i tried a shop crane and got 1 to pop out no damage done to it but it took so much preasure from the crane to pull them out. is there an easier way to pull them out. thanks
  2. #2
    Join Date
    Jan 2012
    Posts
    617
    Winchester Ky
    Allis Chalmers ED 40
    Default Re: 7030 allis chalmer injectors
    When they become stuck that tight, you may have to make some sacrifices. Remove the exhaust manifold(if you haven't already), and unscrew the pressure adjusting screw from one injector. Weld a nut to it that will match the biggest slide hammer you can find. Remove the spring from the injector and thread your new "adapter" back into the body. With some help from a large heel bar under one of the flanges and a strong arm to pull on it, give your slide hammer all you've got and see if it moves. You might also try a big punch to try and rotate them to break the rust bond before attempting removal. Sometimes by the time you get them all out, there's not much left of them.
  3. #3
    Member
    Join Date
    May 2012
    Posts
    28
    Wattsburg Pa
    thank you for your help. I have 5 out of 6 out one still is being a pain in the butt.
Similar Threads
  1. allis chalmer 5030
    By Anonymous Poster in forum Buying/Pricing/Comparisons
    Last Post: 01-31-2015, 12:18 AM
  2. 7040 allis chalmer
    By nattynuts5886 in forum Parts/Repairs
    Last Post: 03-25-2013, 09:53 AM
  3. 5040 allis chalmer farm tractor
    By arctel in forum Hydraulics
    Last Post: 07-31-2012, 11:25 PM
  4. ALLIS CHALMER 615 BACKHOE
    By rhansen1964 in forum Construction Equipment
    Last Post: 04-16-2011, 01:19 PM
  5. Buying Advice Allis Chamlers 7030
    By mbort1985 in forum Buying/Pricing/Comparisons
    Last Post: 10-26-2010, 09:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
