Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Apr 2013
    Posts
    1
    worcester ny
    4610 4wd
    Default 4610 4wd 3cyl oil in coolant blows out over flow when cold
    just bought tractor was said to have been through shop. have since gotten home repaired front hub, seals ,pins bushings .started tractor to give test run coolant run out of overflow removed radiator cap found oil in radiator let run no bubbles in radiator. replaced rad. cap run tractor stopped leaking after warm .possible head gasket maybe?
  2. #2
    Gold Member rdbigfarmboy's Avatar
    Join Date
    Jan 2005
    Posts
    428
    Collinwood, TN
    MF, Same,Zetor
    Default Re: 4610 4wd 3cyl oil in coolant blows out over flow when cold
    Is this a ford 4610?
    I think Im hearing the use of radiator block type stop leak. The oily look might be oil or the bars leaks type of stop leak. Either one you will know when you run it more.
  3. #3
    Join Date
    Jan 2005
    Posts
    428
    Collinwood, TN
    MF, Same,Zetor
    Look behind the starter for a small hairline crack in the block. you might have the wrong type of block sealer in the coolant.
Similar Threads
  1. 3-Point Hitch 71 ford 2000 3cyl hyd. oil, trans oil questions
    By FarmerAlan in forum New Holland Owning/Operating
    Last Post: 10-16-2012, 08:32 AM
  2. 4610 su II coolant temp??
    By nightrider2108 in forum New Holland Owning/Operating
    Last Post: 11-13-2011, 08:16 PM
  3. Cold tractor blows "O" ring on hydro filter
    By chuck1975 in forum New Holland Owning/Operating
    Last Post: 03-30-2006, 06:57 AM
  4. BX COOLANT - Check hot or cold?
    By r0GuE in forum Kubota Owning/Operating
    Last Post: 09-24-2004, 10:48 AM
  5. Anybody have 4610 and 4710 4WD MSRPs handy?
    By Muhammad in forum John Deere Buying/Pricing
    Last Post: 07-27-2004, 12:12 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
