Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    Elite Member
    Join Date
    Jun 2011
    Posts
    3,007
    Sunny SW Washington
    LS R4010 & Cub Cadet 7300
    Default Re: metric mower belts Rhino XM750/ Sitrex SM 230
    That belt on eBay doesn't look right. I ordered them today from the NAPA store, as I really want to pull the old ones before they break, and that can't be far off. They charged $52 ea. plus whatever the freight will be from Georgia. I think the belts need this pattern to handle the back bend around those idlers.
    metric mower belts Rhino XM750/  Sitrex SM 230-metricpixsm04-jpg
    The Corporate Empire is NOT a Constitutional Republic...
    ...but it plays one on TV.
  2. #12
    Elite Member
    Join Date
    Jun 2011
    Posts
    3,007
    Sunny SW Washington
    Here's the fix I did for the rusty 'wheel axle' bolts. Though they were metric, I discovered that a 3/8 NC bolt threads freely though the metric captive nuts, if only just slightly loosely. I replaced the bolts with stainless 3 1/2" X 3/8" bolts with stainless fender washers and lock nuts, double nutting the captive nuts after the bolts were well tightened in from the top. I think this will be an okay fix, except it will make opening the belt case a bit of a pain, as I will have to remove the lock nuts each time I open the cases. I will be working on a workaround for that soon.
    metric mower belts Rhino XM750/  Sitrex SM 230-mower-bolts-001-jpg
    metric mower belts Rhino XM750/  Sitrex SM 230-mower-bolts-002-jpg
    metric mower belts Rhino XM750/  Sitrex SM 230-mower-bolts-003-jpg
    metric mower belts Rhino XM750/  Sitrex SM 230-mower-bolts-004-jpg
  3. #13
    Elite Member GManBart's Avatar
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Massey Ferguson 241, Case 580 Super M Series 2, Cat D3B
    Found the belt....Pix makes the correct model.
    PIX USA, Belt Cross Reference
    They're only $34 each here (this is the Pix online catalog), but they call it A-XPB2800:
    https://www.allpartsstore.com/ItemList.htm
    Even better, $11 each on Amazon!
    http://www.amazon.com/Goodyear-Engin.../dp/B00008A526
  4. #14
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Seems like a good price on the correct blades....did some cross-referencing, and this guy says the Caroni 7'7" blade is the same.
    http://www.ebay.com/itm/CARONI-TC910...E:L:OC:US:3160
  5. #15
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Quick update. The first couple of uses, I managed to pop one of the belts off of the pulleys when hitting heavy grass, or lightly scalping the ground. I noticed that the two belts were obviously different ages, so the tension wasn't matched...having the loose belt correctly tensioned made the newer belt too tight (bad for the bearings).
    So, I got the Goodyear belts from Amazon....$11 each! They fit perfectly, and they aren't popping off the pulleys like the older, incorrect belts were, and I intentionally ran it through some heavy stuff to test it...no problems. The bad news is I just posted a review on Amazon, and noted they increased the price to $25 per belt. I got the last two in stock, so it's likely they were from an earlier purchase, and the prices have gone up. Still, their price is something like $9 cheaper than the next best, and I'm happy they're Goodyear belts made in the USA!
  6. #16
    Member
    Join Date
    Jul 2010
    Posts
    40
    New Holland TC40DA
    If you don't mind me asking, what do you pull this with, I have a tc40da to do misc work with and a client that wants 5 acres mowed once a month, would this tractor pull this and would this mower do a good job mowing a field once a month? Thanks
  7. #17
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Quote Originally Posted by kartingdad View Post
    Sorry for the delay in replying, I must have missed this. I've used this mower with my LS R4047 and MF 241, both of which are a bit bigger than your TC, but I'm certain you would have no problem running it with your machine. My LS had 38.5hp at the PTO, and I think your TC has maybe 5 less, but that will be more than enough.
    Overall, I think the Sitrex gives a nice cut, seems to run smooth, and hasn't given me any problems. Mine had the older pneumatic tires that I just changed over to solid rubber. I found solid replacements online, bought the correct size mounting cone, and pressed them on with a shop press...worked out pretty well in the end and cost about $175 for everything.
    If you're interested in bench vises, I set up a blog/website to share pictures, restoration techniques, and resources: http://www.mivise.com
    Loose = not tight. Lose = to misplace. There = a place. They're = they are. Their = ownership. Advice = what you give when advising someone. Advise = the act of giving advice. Sell = the act of selling. Sale = a temporary discount. Too = also. Two = 2. To = movement, direction or proximity. Brake = device that slows things. Break = separation.
  8. #18
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    To swap the tires from pneumatic to solid, I got the tires from Tiresusa for $35 each, and the mounting cone from Carefreetire for $25 (many places charge $75 for them). You need a shop press to mount the tires, but it's actually an easy process (you can watch YouTube videos on it).
    Amerityre 11x4.00-5 Smooth Solid Mower Tire - TiresUSA.com
    Mounting Cone - Carefree Tire
  9. #19
    Elite Member
    Join Date
    Jun 2011
    Posts
    3,007
    Sunny SW Washington
    Hi folks. Not around here much lately, but I just noticed this. I don't care to do biz with Amazon much, but this price for Goodyear belts is pretty good.
    Goodyear Engineered Products GY Metric XPB2800 Cogged V-Belt, 14mm Height, 17mm Width, 2800mm Datum Length: Industrial V Belts: Amazon.com: Industrial & Scientific
    Now I am dealing with a busted wheel and I see the Italian mowers seem to have the same solid tire wheels on many brands. But all the sources seem to be back east with Ohio being closest to me. Anyone know a source in the PNW? I see them as low as $34 on Ebay.
  10. #20
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Quote Originally Posted by Short Game View Post
    That's the belt I linked above. I bought two before the price increase...worked perfectly.
Similar Threads
  1. SITREX FINISHING MOWER
    By Travis_R in forum Attachments
    Last Post: 06-09-2014, 10:55 AM
  2. Rhino Finish Mower FM 72 Drive Belts
    By uppie in forum Lawn Care & Landscaping
    Last Post: 04-23-2011, 11:05 AM
  3. used sitrex mower
    By wanasrx in forum Attachments
    Last Post: 10-21-2005, 11:00 PM
  4. sitrex finishing mower
    By frank12345 in forum Attachments
    Last Post: 02-29-2004, 05:10 PM
  5. sitrex finishing mower
    By vulcan in forum Attachments
    Last Post: 07-01-2003, 01:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
