Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    New Member
    Join Date
    Apr 2013
    Posts
    13
    farmington,illinois
    JD,IH,AC Cat
    Default Re: JD 820 - Pinhole leak in Fuel Tank
    If your tank is that bad, I would be looking for an after market replacement.I have tried the epoxy treatment in the past with negative results.
  2. #12
    Elite Member JerryK's Avatar
    Join Date
    Feb 2004
    Posts
    2,680
    Vanderbilt, Michigan, USeh?
    Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST
    Quote Originally Posted by lacamo View Post
    But it's only a matter of time before I'll have to replace the tank. I have seen metal and plastic replacements -- any idea which would be better? Thanks for all the responses!
    If it is a on top of the motor tank, I'd go with steel. If it is somewhere else, nothing wrong with plastic. My 1981 JD2240 came with a plastic 20 gallon tank right in front of the radiator. Most of those old tanks were not galvanized...
    78" [26"X10"fan] Mahindra front blower,72" Mahindra front blade, 48" CID QA forks, 6' EverythingAttachments Land Plane & Landscape Rake, 78" JRW rear blower[26"X8"fan], homemade 1 ton rear weight, 6' Ford rear blade, big homemade 3pt box/carrier, 8" wood chipper
  3. #13
    New Member
    Join Date
    Apr 2013
    Posts
    13
    farmington,illinois
    JD,IH,AC Cat
    If I had the choice of steel or plastic, I would go with plastic.The plastic is a very sturdy type that last forever and doesnot rust.The only problem is a fireI have an 1175 Case that had this type of tank that caught on fire and after burning for quite some time it finally heated the three point arm it burned a hole where the arm touched the tank.They are not cheap, that little beauty was over five hundred to replace.
Similar Threads
  1. Pinhole fuel line leak
    By JRobyn in forum Parts/Repairs
    Last Post: 08-23-2012, 10:08 PM
  2. Oil & Fuel Fuel Tank Leak
    By David Cravey in forum Massey Ferguson Owning/Operating
    Last Post: 06-23-2010, 10:40 PM
  3. Oil & Fuel JD 1070 pinhole leak in fuel tank???
    By davefr in forum John Deere Owning/Operating
    Last Post: 05-26-2008, 05:07 PM
  4. Oil & Fuel Another BX Fuel Tank leak
    By JonSpinosa in forum Kubota Owning/Operating
    Last Post: 11-23-2001, 08:38 PM
  5. Oil & Fuel BX fuel tank leak
    By r0GuE in forum Kubota Owning/Operating
    Last Post: 08-07-2001, 08:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
