Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
  1. #1
    Join Date
    Apr 2003
    Posts
    34
    Lufkin, Texas
    Bolens G152
    Default Oil Pan Drain Plug
    OK, Friday evening I was going to change the oil in my tractor. This is only the second time that I have had to change it since I have owned it. Obviously who ever owned it before me did not have the right tools to work with because the head of the oil pan drain plug had been rounded off, like someone had use a standard size wrench when it actually needed a metric wrench. So here is my problem. As I started to loosen the drain plug I could not get any size wrench to fit it, so what happened is the head is now really rounded off and I can not get anything to turn it. I even resorted to the dreaded vice grips in hopes to just get the dang thing out and replace it. So no I am stuck with a drain plug i can not get out!!! I need home help in figuring out how to get the drain plug out. I have used ease outs before, but i am not sure if this will work here. Any help will be greatly appreciated!!!!! [img]/forums/images/graemlins/mad.gif[/img]
  2. #2
    Super Member JerryG's Avatar
    Join Date
    Apr 2000
    Posts
    7,235
    Northwest Arkansas
    MF 1440-4 PowerShuttle
    Default Re: Oil Pan Drain Plug
    Get a 6 point metric socket of the right size. That should take care of your problem, unless it has really been chewed up to where the flats are completely gone.
  3. #3
    Join Date
    Apr 2000
    Posts
    658
    Central Wisconsin
    1986 Ford 1910 with 770B (FORD) loader, 4 MFWD; 1986 Bolens G214,back hoe,loader,MFWD (Iseki) 21 hp)
    I would think a pipe wrench like a plumber uses would do it. [img]/forums/images/graemlins/smirk.gif[/img]
    I've taken a 4-4 1/2 inch angle grinder and "resized" and flattened 2 opposing sides on the hex so a wrench will grab hold. [img]/forums/images/graemlins/wink.gif[/img]
  4. #4
    Epic Contributor RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    22,279
    Bethel, Vermont
    John Deere 4520 MFWD, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
    I went through this crap the first time I tried changing the oil on my (1991) Deere 670.
    The plug wasn't rounded, but was impossible to turn with the correct socket on a 24" breaker bar. I even bought a 6 point socket (less likely to "round" the corners using a six point socket).
    Well, I ended up sending the tractor to the dealer's. I reckon the last time the oil was changed, the plug had been installed with an air wrench rather then torqued to the proper specs.
    I made sure the plug was torqued by hand this time.
    As much as it may be a drag, you may have no option but to send your machine to the dealer. Once is OK...but shame on us if we have to do it a second time!
  5. #5
    Elite Member
    Join Date
    Mar 2002
    Posts
    3,961
    What happens when you try to remove it with a vicegrip? The tool can only slip, (get a pipewrench), or you need a pipe extension on the vicegrip. Remember, (righty tighty, lefty loosey) [img]/forums/images/graemlins/tongue.gif[/img], and I have seen guys get confused when the bolt head is facing away from them.
  6. #6
    Join Date
    Apr 2003
    Posts
    34
    Lufkin, Texas
    Bolens G152
    I think pipe wrench may be the fix i need. Don't know why I did not think of that!!
  7. #7
    Super Member Inspector507's Avatar
    Join Date
    Mar 2002
    Posts
    5,905
    Central Ohio
    Try a bolt/nut remover from Sears/Craftsman. Go to Craftsman.com and search on nut remover. Attached is a pic.
    Attached Images Attached Images
  8. #8
    Join Date
    Dec 2002
    Posts
    1,535
    Blair, Ne.
    L3130
    We all need a nudge now and then [img]/forums/images/graemlins/smile.gif[/img]
  9. #9
    Join Date
    Jul 2003
    Posts
    100
    Wisconsin
    Red, blue, orange, green...did I miss any?
    Before you try any method make sure you have the replacement plug bought! [img]/forums/images/graemlins/wink.gif[/img]
  10. #10
    Join Date
    Apr 2003
    Posts
    34
    Lufkin, Texas
    Bolens G152
    kind of hard for me to buy the replacement plug first when i don't know the size.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
