Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    May 2012
    Posts
    13
    Westchester County, NY
    Deere L118
    Default Deere L118 stator - HELP!!!
    The stator is under the flywheel, yes?
    What is the best way to prevent the flywheel from turning if I need to remove it? There is some rust, of course, so I have it soaking in PB Blaster. Anyone know what size socket I need to remove the nut on the flywheel if I have to remove it? 1 1/2? 1 3/4?
    I have lots of experience on cars and motorcycles, but this is my first semi-major repair to my L118.
    Your help will be appreciated.
  2. #2
    New Member
    Join Date
    May 2012
    Posts
    13
    Deere L118
    Default Re: Deere L118 stator - HELP!!!
    help!
    Anyone?
  3. #3
    Join Date
    Apr 2009
    Posts
    197
    Use a impact gun to remove the nut, or strike the end of the wrench with a hammer if you dont have the impact wrench.
  4. #4
    New Member
    Join Date
    May 2012
    Posts
    13
    Deere L118
    Quote Originally Posted by kencunningham View Post
    best method for removing rust and stopping it from turning while removing the nut/bolt?
  5. #5
    Veteran Member jimmysisson's Avatar
    Join Date
    Jul 2005
    Posts
    2,344
    W.Mass
    1993 NH 2120 (the best), 1974 MF 135 (sold, but solid), 1947 Farmall A (bought, sold, bought back, sold again), 1956 MH50 lbt (sold, in 1980, darn it)
    If you have an impact wrench, you can hold the flywheel with your hand. If you don't, can you borrow one?
    Once the nut is loosened, run it up so it's flush with the threads on the end of the crank. Pay good attention to the design of the crankcase, and place a prybar under two sides of the flywheel, giving slight pressure (use a friend or a knee on the second one). Tap the end of the crankshaft with a brass hammer or lightly with a ball peen hammer, and the flywheel should pop. Use a new key when replacing.
    Jim
    "Anything worth doing is worth doing slowly" Mae West
  6. #6
    Join Date
    Jul 2014
    Posts
    97
    NE Ohio
    John Deere F935
    They make an actual tool to rotate and hold the flywheel by the teeth. It gives a lot more leverage than just your hand, and makes it so you can use hand tools if needed/desired. I call it a flywheel wrench but it probably also has other names:
    Deere L118 stator - HELP!!!-ft23800-jpg
    I have also used a "custom" method to hold a rotating assembly as you unbolt it. Doing this means you have to get at least one bolt out though. I took a piece of flat steel bar and drilled a hole at each end. On one end I used the removed bolt and bolted the end of the bar to the assembly. The other end I used to bolt a chain to it and ran the chain to a suitable anchor. Then, I simply unbolted the rest with a ratchet. The assembly will only spin so far, then lock itself from turning.
Similar Threads
  1. John Deere L118 Engine problems
    By nickb1968 in forum John Deere Lawn & Garden
    Last Post: 07-19-2014, 10:24 AM
  2. John Deere L118 seems backwards
    By SgtDeadeye in forum John Deere Owning/Operating
    Last Post: 09-11-2012, 05:45 PM
  3. John Deere L118 dies
    By ctwith3 in forum Owning/Operating
    Last Post: 05-20-2012, 06:24 PM
  4. john deere L118
    By lberryhill in forum John Deere Lawn & Garden
    Last Post: 04-27-2012, 03:27 PM
  5. Cub LT1050 Or Deere L118
    By got2lb in forum John Deere Lawn & Garden
    Last Post: 07-03-2005, 11:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
