Results 1 to 3 of 3
05-06-2013, 09:21 PM #1
- Join Date
- May 2013
- Posts
- 1
- Location
- lowell,in
- Tractor
- JD318
hydrostatic lever adjustment JD 318
I put the lever in neutral and the tractor creeps forward. How do I adjust it? Help please. Thanks in advance
05-07-2013, 08:47 AM #2
- Join Date
- Jan 2010
- Posts
- 3,858
- Location
- Northern, IL
- Tractor
- Branson 2400H, JD X540
Re: hydrostatic lever adjustment JD 318
From memory there is some adjustment linkage under the hood/ dash. May be down closer to the transaxel. (Been several years since I worked on one) If I also recall correctly it was very touchy to adjust. You have to study how the linkage works to determine if you need to shorten or lengthen the adjustment rod.
Artificial Intelligence will never overcome natural stupidity.
Branson 2400H MMM & FEL
JD X540
05-07-2013, 10:08 AM #3
- Join Date
- Sep 2005
- Posts
- 79
See the image below. #28 on the parts diagram is an eccentric that is designed to give you the adjustment you need. On the other hand, I found it much easier to cut a section out of #38 and weld in a turnbuckle on my 420. It appears that the linkage is slightly different on the 318 than the 420 however...So, proceed with caution!
Similar Threads
TC31DA Hydrostatic Creeping Adjustment
By kycontrols in forum New Holland Owning/OperatingReplies: 3Last Post: 05-21-2012, 11:03 AM -
Hydrostatic transmission adjustment
By Leo Rabon in forum Craftsman / SearsReplies: 3Last Post: 11-30-2011, 09:55 AM -
3 pt lift lever on GC adjustment?
By Wacky in forum Massey Ferguson Owning/OperatingReplies: 3Last Post: 08-31-2011, 08:02 PM -
Mowing Seat adjustment lever & mowing
By bindian in forum Mahindra Owning/OperatingReplies: 5Last Post: 07-26-2007, 09:43 PM -
hydrostatic automatics: foot pedal vs lever
By beowulf in forum General Lawn & GardenReplies: 7Last Post: 04-11-2006, 10:27 PM
