Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    May 2013
    Posts
    1
    Zanesfield , Ohio
    Kubota B7610
    Default Oil Change on woods finish mower
    I have 54 inch woods RDC heritage finish mower an it appears to have water in the gear bow how do I drain this and get all the H2O out and then add new oil there is no drain plug only a fill level plug on side of the box.
  2. #2
    Gold Member
    Join Date
    Feb 2011
    Posts
    405
    princeton nc.
    JD 2320
    Default Re: Oil Change on woods finish mower
    3 ways, turn mower over, take gearbox off, or suck out oil with turkey baster or something similar.
    2010 JD 2320, 200cx, Frontier 1060R RFM, 2048 BB, LR1072 rake, IMatch, 5 suitcase weights.
    NEED MORE IMPLEMENTS!
  3. #3
    Epic Contributor RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    22,628
    Bethel, Vermont
    John Deere 4520 MFWD, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
    Pumping it out is the easiest way, but you'll want to get the 90W gear oil hot.
    However, Woods doesn't recommend changing the oil...not even a procedure in the manual. If you do change the oil, make sure you don't overfill!
    Roy Jackson
    "There ain't no such thing as a free lunch..."
  4. #4
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,537
    Lincoln County, NC need new avatar!
    Just a Scag
    It's usually very difficult or impossible to get the tube of a suction device down between the bearings on the vertical shaft. Therefore the heavier water will remain at the bottom of the gearbox. I flipped my RM990 over and drained the gearbox last Fall and let it drain overnight. Got some real good "stuff" out of it.
    Spring is the season of optimism.
Similar Threads
  1. Rear Finish Mower Woods 200 FInish mower
    By Lizard7159 in forum Attachments
    Last Post: 08-27-2011, 09:54 PM
  2. Finish Mower Belt Change
    By mrmanners in forum Attachments
    Last Post: 07-27-2011, 02:20 PM
  3. Woods PRD finish mower??
    By Newblue in forum Attachments
    Last Post: 07-15-2010, 06:51 PM
  4. Woods finish mower, RM-59 I think
    By chut in forum Attachments
    Last Post: 07-30-2005, 02:52 PM
  5. woods finish mower
    By revg62 in forum Attachments
    Last Post: 01-12-2003, 12:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
