Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    May 2013
    Posts
    1
    Parksley VA
    Massey Furgurson
    Default Massey Furguson 3545 oil leak
    Hey guys, I am looking into purchasing a Massey Ferguson 3545. It is a tractor that the previous owner had not used it much, so it has been sitting, has low hours but some issues. The 3 point hitch is not operating but I believe it is a electronic issue. After running it for 40 mins I also notice a oil leak, 2 solid lines on the side of the tractor in the picture I am attaching. There seemed to be some build up of oil on the lip of the oil pan in front of the engine. I could not tell where the leak was coming from. By looking at the pictures can any guess the possible sources and the involvement of repairing it. I was talking to a friend on the phone and they thought maybe the crankshaft pulley seal is bad.
    Attached Thumbnails Attached Thumbnails Massey Furguson 3545 oil leak-img_0982-jpg   Massey Furguson 3545 oil leak-img_0984-jpg   Massey Furguson 3545 oil leak-img_0981-jpg
  2. #2
    Veteran Member banjodunn's Avatar
    Join Date
    Jun 2008
    Posts
    1,429
    Ararat Vic Aus
    Default Re: Massey Furguson 3545 oil leak
    G'day and . It is hard to tell if it is front seal leaking from your pics but it would be reasonable to assume that considering location. I would be running it for a while before I did any thing as you have to move the front axle housing forward about an inch to get the harmonic balancer off, also the last one I did I had to cut the balancer off as the little wedge rings would not come free. As for the linkage if the ELC unit is playing up and you do not need draft control then I just put in a 3 way spring centre toggle switch and a couple of relays and wire directly to the solenoids. If you want to override the elecs you can do that by manually operating the solenoids on the back of the TPH cover, you will see them if you stand at the back of the tractor, on the end of the solenoid is a small button that you can push but it does take some effort.
    Jon
Similar Threads
  1. Buying Advice Massey Ferguson 3545 MFWD
    By jlar in forum Buying/Pricing/Comparisons
    Last Post: 04-20-2013, 04:18 AM
  2. Massey furguson 1030
    By naharris in forum Massey Ferguson Owning/Operating
    Last Post: 05-01-2012, 01:53 PM
  3. My Bobcat pulled a Massey Furguson
    By duckhunter27 in forum Bobcat Tractors
    Last Post: 02-15-2012, 01:58 PM
  4. How Much To Ask...Massey Furguson
    By MF1230LA in forum Buying/Pricing/Comparisons
    Last Post: 04-14-2011, 07:40 AM
  5. massey furguson 254 4WD
    By zekeman in forum Buying/Pricing/Comparisons
    Last Post: 07-23-2004, 08:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
