Results 1 to 3 of 3
  1. #1
    Platinum Member BarryinMN's Avatar
    Join Date
    Feb 2003
    Posts
    860
    Minnesota
    JD, Allis-Chalmers, Zetor
    Default \'48 JD A transmission filler hole?
    Can anyone tell me where the transmission filler hole is?
    Engine and Power Trol are easy to spot.
    Thanks,
  2. #2
    Member
    Join Date
    Nov 2001
    Posts
    46
    Clinton Ark
    Kubota L-3600 GST/FEL
    Default Re: \'48 JD A transmission filler hole?
    Had a "B" J.D. of about the same vintage and a breather pipe on the right side by the pulley maybe close to the magneto. was the filler pipe. How long had you had the "A' ? might find some parts in the tractor shed
    Hope this helps let us know . ken
  3. #3
    Join Date
    Jan 2002
    Posts
    1,927
    Home-1+ acres New Hope, TX / 24 acres-Fannin County
    JD 950
    There is a forum for Vintage Tractors a little farther down the list. You might post there and get more information. If that doesn't work, try yesterdaystractors.com. That site is dedicated to antique tractors. There is a John Deere forum there where you can get pretty much any info you need on any old Deere. Or any other old tractor for that matter.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
