Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Veteran Member Kernopelli's Avatar
    Join Date
    Oct 2006
    Posts
    1,873
    Carterville, Illinois
    Mitsubishi MTE2000D, Dig It 258 Backhoe Deere Z930M ZTR
    Default Re: Honda RT5000 multi-purpose sub-compact tractor engine tear down
    Quote Originally Posted by DarrylH20 View Post
    At least we spell it the right way
    My mother said when they asked her at the hospital how to spell it for the birth certificate my parents realized they hadn't thought it out that far. She said it popped into her head seeing Darryl Zanuck's name on the movie credits and that was the only way she could think to spell it. Works for me!
    Darryl
  2. #22
    Bronze Member SilverLakeFab's Avatar
    Join Date
    Nov 2008
    Posts
    83
    Concord, NH
    Kubota B6100D & Honda RT5000
    The engine is now all back together. As always, Sanel's Machine shop in Concord (NH) did a great job with the bore job and they got it turned around quickly (I've had the block back for about 3 weeks now). The engine is now basically new. It has a new crankshaft, connecting rod, piston, and piston rings. All the shaft seals and gaskets were also replaced. Also everything has been thoroughly cleaned before reassembly and the rear flywheel/fan cowl has been cleaned and painted as it was a little ugly (surface rust). I'm taking a break right now, as it's a little toasty in the shop today, but if I could find the darn float pin, I would be able to have it running today. That said, I'll continue with this thread once the motor is bolted in and running again, but here are some more pictures from this rebuild.
    <p>Honda RT5000 multi-purpose sub-compact tractor engine tear down-photo-2-jpgHonda RT5000 multi-purpose sub-compact tractor engine tear down-photo-jpgHonda RT5000 multi-purpose sub-compact tractor engine tear down-photo-1-jpgHonda RT5000 multi-purpose sub-compact tractor engine tear down-photo-3-jpg
    <p>After the engine is bolted in, I have the fun part of this build to do, which is an exhaust system. The stock system is no longer available, so I have to build or adapt a set-up to make it exit at the correct place. I look forward to posting pictures of that one.
    Aaron Leclerc
    Silver Lake Fabrication
    silverlakefabrication.com
    1978 Kubota B6100 - great little tractor!
  3. #23
    New Member dant2757's Avatar
    Join Date
    Dec 2013
    Posts
    1
    Larkspur, CO
    RT5000
    Great post.
    Do you know how many hours were on the engine before the rebuild?
    These Honda engines seem to last forever.
  4. #24
    New Member
    Join Date
    Jan 2014
    Posts
    1
    united kingdom
    honda rt1100
    Quote Originally Posted by Kernopelli View Post
    Those are cool little tractors. Error if you don't already have it. I have always hoped to run across one somewhere at a price I couldn't pass up, just to have one. Never read anything about the 11HP models being short on power ( even with 1100# combined F/R lift capability). How cool would it be to find one of the later 3cyl diesels w/ factory FEL and backhoe!!
    Hi I have one of these tractors all of a sudden the oil light lit up, I stopped the engine immediately and now it wont start, the lights dont come on or anything, does anyone have an idea what could have happened or supply a link to the manual the one above doesnt work.
Similar Threads
  1. Buying Advice Help in selecting a multi purpose tractor....
    By GaryFr in forum Buying/Pricing/Comparisons
    Last Post: 02-10-2013, 01:43 PM
  2. Multi purpose tractor
    By Robert M in forum Buying/Pricing/Comparisons
    Last Post: 11-28-2012, 08:00 AM
  3. 4-in-1 Construction Attachments Compact 4-in-1 Multi-Purpose Bucket
    By scuvnut in forum Attachments
    Last Post: 05-31-2009, 08:44 AM
  4. Honda RT5000 for the archives
    By Anonymous Poster in forum Photos
    Last Post: 07-13-2008, 06:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
