banjodunn
G'day behind the pto lever is not where you want to go looking it is a clutch problem you have. Make sure your pedal free travel is correct for a start ( 3/8
" between the clutch pedal arm and footrest ) if that is correct then you may need to remove the plate on the bottom of the bellhousing and give the pto levers on the clutch about 60 thou clearance.
It might be a good idea to get a book on it if you have not got one already.
Jon
Jon
