Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Jul 2013
    Posts
    1
    Goodells
    Ford 4000
    Default 1972 Ford 4000 Stalls
    My tractor starts and runs for maybe 10 minutes then stalls. It will start again but only run for 20 seconds or so. This is a 3 cyl gas engine. I have new plug wires and plugs. The carb bowl has gas when I pull the drain plug. The throttle does not seem to raise the RPM's. Any ideas as to what else may be going on would be a big help.
  2. #2
    New Member
    Join Date
    Jul 2013
    Posts
    7
    Wayland,NY
    kioto lb1914
    Default Re: 1972 Ford 4000 Stalls
    i would check for water in the gas. drain some off into a clean dry jar let it sit and look for bubbles the water will seperate.
    Rob
Similar Threads
  1. 1972 ford 3 cyl backhoe
    By Dennis dean in forum Parts/Repairs
    Last Post: 07-21-2013, 12:55 PM
  2. Backhoe 1972 ford 3 cyl backhoe
    By Dennis dean in forum New Holland Owning/Operating
    Last Post: 05-15-2013, 04:04 PM
  3. 1972 Ford 4000 3-Cyl Gas, Various Problem
    By newtraditionsfarm in forum New Holland Owning/Operating
    Last Post: 04-02-2012, 01:15 PM
  4. 1972 ford 4000
    By awnery in forum New Holland Owning/Operating
    Last Post: 03-27-2012, 10:26 PM
  5. hello from Va 1972 ford 3000
    By navydad80 in forum New Member Introductions
    Last Post: 10-10-2011, 07:54 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
