LawnGuys
Hello,
I'm new to the forum. I have a 25 hp Kohler command that had an oil leak coming from the pto shaft. I replaced the shaft seal and let it run for about 15 minutes with no leak. I thought it was fixed. Used the mower for about another 15 minutes and went to pull it in the garage and it started leaking again. It almost seems like it builds up pressure as it warms up and then lets loose. The seal was still in place, but I'm afraid to run it. Has anyone seen any situations where pressure would build up and create a leak like this or is there something more I should be looking for? I'm not even really sure that pressure is building up. It just seems like after I have used the mower for a period of time it starts to leak a lot.
Bryan
Bryan
