Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    New Member
    Join Date
    Aug 2013
    Posts
    5
    cINCINNATI, Ohio
    Ford 1620, 4600
    Default Engine Oil in filter is as clean as the day I changed the oil.
    Why would the oil in the pan get dirty but the color of the oil in the filter stay as clear all season? This is a 1995 Ford 1620 3 cylinder shibaura diesel engine.
  2. #2
    Join Date
    Oct 2010
    Posts
    687
    Near Peace river -Alberta
    ASV 4810
    Default Re: Engine Oil in filter is as clean as the day I changed the oil.
    I would venture to say the filter is a bypass filter and is for some reason not or no longer included in the oil circulating circuit( blockage or stuck bypass valve?)
    3 cockshutt 1855,1 cockshutt 1800.
    Belarus 800 and 925 .AC 940 whl ldr.Waldon 500 whl ldr.
    ASV 4810 tracksteer.
    4 GMC 2500 6.5/6.2 diesel trucks
  3. #3
    Join Date
    Oct 2010
    Posts
    595
    New Holland TC 29D
    Are you sure that you have the right filter for that engine? If it is the wrong filter you may not be getting any oil through it.
    TC-29DA
    BX-1500
  4. #4
    New Member
    Join Date
    Aug 2013
    Posts
    5
    cINCINNATI, Ohio
    Ford 1620, 4600
    I used a NAPA 1521 and also a New Holland 86533216 but got the same results; Clean oil in the filter
  5. #5
    Veteran Member banjodunn's Avatar
    Join Date
    Jun 2008
    Posts
    1,457
    Ararat Vic Aus
    G'day do you prefill the filter before fitting? If so then I would get a new filter and not fill it and fit it to the engine and start the engine, shut it down after the oil pressure light goes out and pull the filter off and check for oil.
    If you have not got any oil in the filter then the bypass valve must be stuck open they are usually located in the filter head assy.
    Jon
  6. #6
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,580
    Lincoln County, NC need new avatar!
    Just a Scag
    You are probably changing the hydrostatic filter on the left. Engine oil filter is on the right by the fuel filter.
    Spring is the season of optimism.
  7. #7
    New Member
    Join Date
    Aug 2013
    Posts
    5
    cINCINNATI, Ohio
    Ford 1620, 4600
    I do get oil in the oil filter but it stays clear and clean all season. I do not prefill the filter before fitting. After putting several hours or even a season on the 1995 Ford 1620 3 cylinder Sibaura engine, I pull the filter off and find clean oil but the oil in the oil pan is dirty.
  8. #8
    Join Date
    Sep 2000
    Posts
    9,580
    Just a Scag
    Quote Originally Posted by TriCountyKid View Post
    Which filter are you describing?
  9. #9
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Pics, we need pics.
    Murph
  10. #10
    New Member
    Join Date
    Aug 2013
    Posts
    5
    cINCINNATI, Ohio
    Ford 1620, 4600
    No, I am changing the oil filter and NOT the hydrostatic filter.
Similar Threads
  1. ok what oil filter for a y385
    By reelnative in forum Chinese Tractors
    Last Post: 03-08-2017, 11:07 AM
  2. Engine Oil filter for 2011 DK40se HST
    By southerniltractor in forum Kioti Owning/Operating
    Last Post: 07-27-2016, 04:30 PM
  3. have proof kubota oil made by ashland oil
    By displacedPA in forum Oil, Fuel & Lubricants
    Last Post: 07-24-2013, 07:04 PM
  4. Oil in air filter
    By Farmall140 in forum Power Trac
    Last Post: 06-09-2013, 09:47 AM
  5. Replies: 7
    Last Post: 05-09-2013, 02:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
