Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Aug 2013
    Posts
    3
    Parkersburg wv
    M/F C/cadet
    Default Belt tensioner on a cub cadet 1554
    I am trying to see if anyone has a fix for the belt tensioner on cub gt1554 deck it seems the bolt that goes through the deck keeps coming a ;ittle loose and the bolt or stem keeps tilting a little and lets the belt come off quite often i have replaced the lock nut on the bottom a couple of times and it keeps loosening over time i have thought about welding a piece of 1/4" plate on the bottom of the sleeve to get a little more surface area on the deck to keep it upright but wanted to see if anyone has had this problem and there fix. Thanks fo any help
  2. #2
    Join Date
    Apr 2009
    Posts
    197
    Default Re: Belt tensioner on a cub cadet 1554
    Put red loctite on it, it shouldn't come loose after that.
  3. #3
    New Member
    Join Date
    Aug 2013
    Posts
    3
    Parkersburg wv
    M/F C/cadet
    Quote Originally Posted by kencunningham View Post
    I took it appart this evening and the shoulder that sits on the deck has the side worn and thats one reason it is sitting at an angle the nut was actually still tight. The shoulder is just a pc of pipe over the stud and it is worn on 1 side with the tension on it is is tilting. I think i am going to make a washer about 2" diam. out of 1/4" bar with a hole to slip up on the pipe and weld that so there will be more surface area on the deck to keep it staight.
  4. #4
    Gold Member
    Join Date
    Nov 2012
    Posts
    255
    Newark, de
    International 424
    We would weld a heavy flat washer to the end of the sleeve and put a large flat washer on the underside of deck then use locktite on it. Also check to see if belt is burned or blades out of balance. That will cause vibration and loosen a lot of stuff up.
Similar Threads
  1. Cub Cadet 124 vs Cub Cadet 129
    By docrocky in forum Cub Cadet L&G
    Last Post: 07-18-2013, 10:56 PM
  2. Replies: 2
    Last Post: 07-10-2013, 10:35 AM
  3. cub cadet super lt 1554 drive belt replace
    By sam5570 in forum Cub Cadet L&G
    Last Post: 04-02-2013, 10:47 AM
  4. Where to mount a belt tensioner?
    By PutnamVictor in forum Build-It Yourself
    Last Post: 08-20-2010, 11:34 AM
  5. 1050 drive belt tensioner
    By sbatzold in forum Cub Cadet Tractors
    Last Post: 11-13-2005, 10:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
