Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Oct 2013
    Posts
    2
    lutz, fl
    Troy Bilt 42in
    Default Electric system died on Troy-Bilt 42in mower
    Hi,
    I have a Troy-Bilt 42in Tractor Mower with a Kohler engine. Today I changed the upper and lower Drive belts. When I put everything back together, I have zero electric power. The 20A fuse next to the battery is good. I tested the battery and it's good. When I turn the key, the mower doesn't even flinch. Not a sound. Nothing.
    I suspect it has something to do with the safety mechanism that shuts the mower off when in reverse, but I don't know where is that located. Any other ideas? I appreciate any help.
    PG
  2. #2
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,901
    South West MI
    John Deere 2030, John Deere 6415
    Default Re: Electric system died on Troy-Bilt 42in mower
    Use a test light and starting at the battery follow the positive wire and check for voltage at every connector until you get to the ignition switch.
    Check the battery terminal connections (clean and tight) Check the ground cable.
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  3. #3
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    7,083
    Northern Vermont
    Kubota, Case, Deere
    If you got to a website that has the parts breakdown for the mower you can see where all of the switches are. I also have a "super Bronco" Troy built mower. I have removed some of the wires and it disables the switch, the engine and mower still work fine. Mine has a stupid feature that doesn't allow you to mow in reverse unless you push a triangle button near the key. I suspect that you either pinched a wire and it's shorting to ground or you damaged a switch when installing the belts.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  4. #4
    New Member
    Join Date
    Oct 2013
    Posts
    2
    lutz, fl
    Troy Bilt 42in
    Thanks for the replies. Before checking the replies i was visually inspecting the wires and wiggling the connectors and now there's power to the headlights, but still no power to start. So maybe it is the battery after all, unless you have other ideas. I'm trying to avoid buying a battery if i don't need to.
    New info: I had the battery connected but not in the battery well. It was lying on its side and I was charging it (just in case, 6A 12V) and liquid started pouring from the sides of the battery. I was tempted to taste it to see if it was water or acid, but decided against it.
Similar Threads
  1. Replies: 1
    Last Post: 03-31-2010, 10:55 AM
  2. Troy Bilt Mower issues
    By RonR in forum Rototillers
    Last Post: 07-05-2006, 09:22 AM
  3. Troy Bilt Mower issues
    By RonR in forum General Lawn & Garden
  4. Troy Bilt Sickle Mower
    By Saxman in forum General Lawn & Garden
    Last Post: 03-11-2004, 01:15 PM
  5. Troy Bilt Sickle Mower
    By Saxman in forum Rototillers
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
