Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Oct 2013
    Posts
    3
    beaune
    john deere 2030
    Default looking for wiring diagram of JD 2030
    hello everybody,
    I just recently bought a 74 JD 2030 and should have looked at it better - the wiring is all messed up, connectors loosened, wires broken or not hitched up and I am glad it even starts!
    I will need to redo it, but do not have a manual.
    Is anybody out there who has one of those diagrams scanned, as pdf or else? Would greatly appreciate your help!
    best! st0e
  2. #2
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,807
    South West MI
    John Deere 2030, John Deere 6415
    Default Re: looking for wiring diagram of JD 2030
    Gas or diesel? Above or below serial number 187300? the wiring changed after this serial number.
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  3. #3
    New Member
    Join Date
    Oct 2013
    Posts
    3
    beaune
    john deere 2030
    thanks for your reply, Zebrafive!
    it is a diesel driven 4219 DL-03, type 2030 B with a serial number in the 113...L
    to be honest: looking at pictures of various 2030ies, I am confused about what the differences are and what might be the key features to look for
  4. #4
    Join Date
    Aug 2010
    Posts
    3,807
    South West MI
    Was the serial number you posted tractor, not engine? Serial number for 1974 started at 140000L or 187301T
    Here are some differences:
    Engine; gas, diesel
    Trans; 8 speed collar shift, 8 speed collar shift with HI- LO, Reverser
    Front axle; swept back adjustable, straight (non adjustable), straight adjustable, HD straight adjustable
    Exhaust; vertical, horizontal
    PTO; none, 540 rear, 540/1000 rear, 540/1000 rear & 1000 mid
    PTO clutch; one stage of two stage foot clutch, hydraulic lever operated
    Fenders; shell, row crop
    Rear axles; rack and pinion, flanged
    Rear SCVs; none, one, two
    Lower 3pt arms; fixed, telescoping
    Engine side plates/frames; with, without
    Wheels & Tires; MANY! I have 16.9 - 28 rears on power adjust wheels 11L- 15 fronts
    Hydraulic pump; two sizes
    I am sure there are other options I am not aware of
    Attached Thumbnails Attached Thumbnails looking for wiring diagram of JD 2030-roadtrip-003-jpg   looking for wiring diagram of JD 2030-tractor-004-jpg   looking for wiring diagram of JD 2030-tractor-006-jpg
  5. #5
    New Member
    Join Date
    Oct 2013
    Posts
    3
    beaune
    john deere 2030
    thanks! and sorry, my misunderstanding: yes the number is the chassis number; the engine number is 142XXX CD
    it's a diesel 8speed w hi/lo, 2wd, short vertical exhaust, power steering, 540 pto in there, tires 13.6.r x 36 - 7.5 x 16, and more that I don't know (I am just a Newbee)
    adding some pictures will help, I guess... and you might be able to tell much more!
    (oh, and btw: your 2030 looks impressive - wish I had a front loader like that! :-))
    Attached Thumbnails Attached Thumbnails looking for wiring diagram of JD 2030-jd2030-20130911-6-jpg   looking for wiring diagram of JD 2030-jd2030-20130911-2-jpg   looking for wiring diagram of JD 2030-jd2030-20130911d600184012-jpg   looking for wiring diagram of JD 2030-jd2030-20130911-5-jpg
Similar Threads
  1. JD 2030 WIRING DIAGRAM
    By dhiettjr in forum Parts/Repairs
    Last Post: 04-28-2011, 11:03 PM
  2. Wiring diagram
    By skip24jack in forum Mitsubishi/Satoh
    Last Post: 10-17-2009, 09:30 AM
  3. wiring diagram deere 2030
    By mates in forum John Deere Owning/Operating
    Last Post: 09-28-2009, 02:48 PM
  4. Wiring diagram
    By valleydweller1 in forum Build-It Yourself
    Last Post: 03-23-2008, 03:25 PM
  5. I need a wiring diagram!
    By Dachshund in forum Case-IH
    Last Post: 10-12-2004, 09:17 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
