Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,199
    Central Ohio
    Kubota MX5100
    Default Broke my side-link.....AGAIN
    Was bushhogging this morning and went to raise the cutter and herd a bang. Looked back and only one lift arm was raising. Yep, broke a sidelink again.
    Both have been broken before, and re-welded. Last two were broke when doing some blading.
    Luckily, I was only about 10 minutes from home, and was able to run home and fix. Total downtime from the job as 45 minutes, which includes running home, fixing, returning, and re-leveling the cutter.
    I have an old toplink that I think I may make a spare or two out of. That is one for sure way to never break another one. These kubota sidelinks arent made nearly heavy enough IMO
    Ground the thread rod to almost a point, but I didnt show that. I also added a 1/4" x 1" x 3" long strap to the one side to help strengthen it.
    Broke my side-link.....AGAIN-img_20131029_091110_866-jpgBroke my side-link.....AGAIN-img_20131029_091816_915-jpgBroke my side-link.....AGAIN-img_20131029_092429_796-jpg
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  2. #2
    Super Star Member ovrszd's Avatar
    Join Date
    May 2006
    Posts
    17,643
    Missouri
    Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
    Default Re: Broke my side-link.....AGAIN
    Bummer. Looks like the strap will help, long as you don't need to shorten the link past that point. curious to see if this stops the problem.
    Richard
    "Happiness isn't having everything you want, it's wanting everything you have."
  3. #3
    Join Date
    Apr 2008
    Posts
    18,199
    Central Ohio
    Kubota MX5100
    Well, its only broke twice now in 6 years, and I am pretty hard on my hitch.
    Just not a very strong design IMO. The threaded rods are too small, and the solid link on the other side is only like 3/4" diameter.
    I will make something stronger I think.
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  4. #4
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,901
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Maybe you could use a top link and modify it to work, something like from a Cat 3 top linkage. You could sleeve the top to fit the kubota top linkage.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  5. #5
    Elite Member
    Join Date
    Mar 2009
    Posts
    3,607
    Lee, IL
    John Deere 1070
    Default
    When I bought my tractor the threaded rod was very stiff in the threaded tube... I could not turn the crank. I took the whole thing apart and loosened them in vise with a pipe wrench. It weakened the threads a lot and eventually the threaded rod pulled out of the tube and dropped the right lift arm. I welded it in place at equal length to the lefr arm, but now have no adjustment.
    Not counting the cost of the valves, it will be cheaper to get a tnt from fit-rite than repair the lift arm. That is probably what I will do.
  6. #6
    Elite Member GManBart's Avatar
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Massey Ferguson 241, Case 580 Super M Series 2, Cat D3B
    Time to order a side link from Fit Rite!
  7. #7
    Super Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    7,431
    Southern VT
    '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower. Diamondplate aluminum canopy.
    It's obvious why it keeps breaking- look at pic 2 where you used purple bubble gum to hold it together!
    What do you do that stresses them enough to break them?
    2010 DK-40se/HST, KL-401 FEL, (reversible cutting edge). Titan Tree Shear. 72" Ratchet Rake. Fit Rite: Top-N-Tilt hydraulics & diverter. HLA Series 2000 7' plow, Aquiline MPC rear chains. Samuri Sickle bar.
    2016 Mechron 2200PS. 2016 Cub Cadet Pro Z 160 AW Steering, Kawa 23.5HP. 2015 Husky 322T AWD Rider, Combi 103 deck. Dr. Brush mower, & 42" lawn deck, & Dr. 6.5HP Trimmer/mower.
    Bunch of STIHL chainsaws: 011x 2, MS192T, MS200T, MS180C, MS230, MS270 (Wood Boss), 038 Farmboss.
  8. #8
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,175
    Branson, Mo.
    Kioti DK35se Hydrostat
    Well hey, the good news is, it ain't no "thang" for a man with a welder.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  9. #9
    Join Date
    Jun 2009
    Posts
    28,175
    Branson, Mo.
    Ha!.. dang 'bota's held together with Purple Bubble Gum... what is the world coming to
    James K0UA
  10. #10
    Join Date
    Apr 2008
    Posts
    18,199
    Central Ohio
    Kubota MX5100
    Quote Originally Posted by Gary Fowler View Post
    That would be overkill. Just a standard cat 1 toplink from TSC is about twice as big as my side link, and has the right sized hole already. I'll go snap a picture of a TSC cat I link next to my side link....
    Quote Originally Posted by mikehaugen View Post
    I'd have over a grand invested by the time I got two remotes installed, and then the TNT kit. Dont really want to spend that much on something I would rarely use. I am sure I would use it more if I had it, but I dont think I would see a grand worth of time savings and use out if it for quite some time.
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
Similar Threads
  1. Broke Check Link
    By rwork in forum LS Tractor Owning/Operating
    Last Post: 10-08-2012, 02:00 AM
  2. Replies: 70
    Last Post: 08-06-2011, 07:52 PM
  3. Side Link
    By petegoud in forum Build-It Yourself
    Last Post: 04-16-2008, 11:41 PM
  4. Broke rt side knucle arm
    By gladehound in forum Kioti Owning/Operating
    Last Post: 04-14-2008, 10:44 AM
  5. Broke my side lift
    By fenneran in forum Attachments
    Last Post: 12-05-2003, 06:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
