Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    New Member larryd314's Avatar
    Join Date
    Jan 2014
    Posts
    22
    bella vista ar
    81 jd314 garden tractor
    Default Alternator
    My charging system has quit working. So just to be different since I don't use my mower deck I'm thinking of using a small alternator mounted under the tractor where the mule drive would be and driving off the pto pulley.
    Does anybody have any thoughts or ideas?
    larryd314
  2. #2
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Default Re: Alternator
    Quote Originally Posted by larryd314 View Post
    larryd314
    Will it spin fast enough?
    Murph
  3. #3
    Join Date
    Jan 2014
    Posts
    22
    bella vista ar
    I don't believe that would be a problem since it has a constant voltage. A typical car engine idles from 650 to 8oo and the alternator would be turning 1200 to 1500 rpm. and will produce 13.5-14 volts so that rpm chould be no problem.
    larryd314
  4. #4
    Elite Member CobyRupert's Avatar
    Join Date
    Oct 2012
    Posts
    3,354
    Washington County, NY
    JD 5075E
    Default
    Starting might be easier, I guess, as your not turning the alternator.
    Being on the bottom of tractor can you keep it out of mud and snow?
    I guess if your hear tractor sputter, that's your sign that you forgot to turn on PTO.
    JD5075E, Frontier RC2084 Rotary Cutter, Wallenstein FX65 Skidding Winch
  5. #5
    Silver Member Papasmirf's Avatar
    Join Date
    Jul 2013
    Posts
    130
    Washington, Oklahoma
    2007 New Holland TC30
    Default
    Doesn't your PTO operate at 540 rpms? Assuming you operate your tractor at 2000 rpms, the pto is only turning 540 rpms. Plus all the dirt, weeds, seed, and junk on the ground will make short work of that alternator, plus a fire danger.
  6. #6
    Join Date
    Jan 2014
    Posts
    22
    bella vista ar
    I generally operate my engine at full throttle approx. 3400rpm. and control speed with hydro. most hydros work best like that.
    It wouldn't hand as low as mule drive and I would put a shield on it similar to a mule drive.
    larryd314
  7. #7
    Super Member
    Join Date
    Apr 2004
    Posts
    6,504
    East Coast of Lake Huron
    Deere, several
    Why go and jackleg the tractor when all it needs is a stator or voltage regulator? Have you done any trouble shooting? Could be a simple 10 minute fix.
  8. #8
    Join Date
    Jan 2014
    Posts
    22
    bella vista ar
    Everything would be bolt on and something different.
  9. #9
    Join Date
    Jul 2013
    Posts
    130
    Default
    But your pto is still only turn 540 RPMs. I still think it would be better and simpler to fix what you have and put your inventing ness to better use some place else. Please don't take me wrong, I think your creativity is wonderful. I just don't think this is the right point to reinvent the alternator mount. But good luck.
  10. #10
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,639
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    larryd314
    I assume from your Profile, that you have something like this?
    Alternator-jd-314-jpg
    Unless you already have an alternator with an internal regulator, it would cost less to fix the charging system.
    It may just be some corroded connections or the voltage regulator.
    Hold "Ctrl" (Control) and click on a picture or a Link, to open it in a new Tab.
    My Avatar, the TORO+Loader:
    Kwik-Way FEL and TORO Groundsmaster Put Together
    V417 Compact Telehandler: ​(This replaced my tractor): The best machine to do what I need a machine to do
Similar Threads
  1. Replies: 56
    Last Post: 04-01-2013, 07:28 AM
  2. New Alternator!
    By succor in forum Chinese Tractors
    Last Post: 03-06-2011, 06:49 PM
  3. Alternator
    By Prodirt6000 in forum Kubota Owning/Operating
    Last Post: 01-24-2010, 06:20 PM
  4. Where is the alternator??
    By NewClimber in forum Kubota Owning/Operating
    Last Post: 04-04-2007, 10:50 AM
  5. alternator
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 05-25-2000, 05:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
