Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Join Date
    Aug 2001
    Posts
    7
    Wheeling, WV
    L3710 HST
    Default Ballast Injector For Rear Tire Ballast
    Does anyone know where I can buy the tool that attaches to the valve stem to inject ballast into the tires? If so, who makes it and what is the manufactures part number? [img]/forums/images/graemlins/shocked.gif[/img]
  2. #2
    Epic Contributor Bird's Avatar
    Join Date
    Mar 2000
    Posts
    36,981
    Texas
    Default Re: Ballast Injector For Rear Tire Ballast
    Are you talking about an air/water adapter? If so, try this link for just one of many.
  3. #3
    MLB
    MLB is offline
    Join Date
    Aug 2002
    Posts
    218
    Fort Wayne,IN (NE)
    New Holland TC33D
    Default How about the reverse?
    I'd like to unload my loaded tires? [img]/forums/images/graemlins/blush.gif[/img]
  4. #4
    Elite Member
    Join Date
    Oct 2000
    Posts
    3,044
    Windham County, Conn
    Ford 2120 , New Holland TN75D, Hitachi UH083LC Excavator
    Default Re: How about the reverse?
    Why? But anyway, park with the valve stems on the bottom and either jack the machine up and drain into a bucket or put the adapter on, hook up a pump in the opposite direction and pump it out. You could also do it without a pump by pumping up the tire with air and then changing over to the hose adapter. The air pressure will push the fluid out. You will have to pump up the tire several times to get out all of the fluid.
    PS What type of fluid is in your tires?
    Have fun LOL
    Andy
  5. #5
    Join Date
    Mar 2002
    Posts
    570
    Jackson County, Michigan
    Bolens HT-20
    I got mine from NAPA. About $7 I think it was....
  6. #6
    MLB
    MLB is offline
    Join Date
    Aug 2002
    Posts
    218
    Fort Wayne,IN (NE)
    New Holland TC33D
    bought it used, were loaded when I got it so I don't know what they used, don't need them for my use, extra weight is a detriment. [img]/forums/images/graemlins/frown.gif[/img]
  7. #7
    Join Date
    Feb 2004
    Posts
    14
    That comment abou extra weight is right on if you don't have a FEL. All you do is use more fuel for driving a heavy machine and tyre wear. I contracted with a mowing tractor for yrs and with and without water in the tyres was able to reduce my wear heaps.
    Russ
  8. #8
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    46,360
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Napa or TSC
    Soundguy
  9. #9
    Super Member Henro's Avatar
    Join Date
    Jul 2003
    Posts
    5,294
    Few miles north of Pgh, PA
    Kubota B2910, BX2200, Yardman 20HP pos...
    This is what I did...to fill the tires on my B2910 Kubota. It would work equally well for taking fluid out.
    Picture is of when I tested the idea on my little garden tractor...
    Just take out the valve stem, slip a hose over the stem, and hold it on with a hose clamp. Cheap, simple and easy... [img]/forums/images/graemlins/smile.gif[/img]
    Attached Images Attached Images
  10. #10
    Join Date
    Mar 2000
    Posts
    36,981
    Texas
    </font><font color="blue" class="small">( Just take out the valve stem )</font>
    Uh . . ., you leave the valve stem, but take out the valve core. [img]/forums/images/graemlins/wink.gif[/img]
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
