Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Jan 2014
    Posts
    3
    azle tx
    ford
    Default jd sickle pto shft
    I am in need of the pto shaft that goes from the tractor to the second shaft on the sickle. Any help would be greatly appreciated. Thanks
  2. #2
    Advertiser sweettractors's Avatar
    Join Date
    Jul 2003
    Posts
    7,616
    Central Kentucky
    JD 6403 CHA-JD 3130 CHA
    Default Re: jd sickle pto shft
    Quote Originally Posted by brian5545 View Post
    Dimensions for the machine end shaft and model of the sickle mower would help? Ken Sweet
    http://www.sweetfarms.com/
    Sweet Farm Equipment LLC (Internet Sales, Shipping All States)
    Shipping Facility
    1815 Defries Rd., Canmer, Ky 42722 Toll Free 1-866-528-3323
    Ken Sweet sweet@scrtc.com
    Shipping Example: Can ship 800 lbs from Ky. to Dallas for $165
    The Northeast shipping corridor is a little more expensive.
  3. #3
    Gold Member
    Join Date
    Mar 2008
    Posts
    313
    If you can provide photos of the end of the shaft along with the diameter that would help. Also if you measure the width of the cap and the distance from cap to cap on the u joint on the mower end of the shaft then the series can be identified. This will help find the correct shaft.
  4. #4
    New Member
    Join Date
    Jan 2014
    Posts
    3
    azle tx
    ford
    Quote Originally Posted by sweettractors View Post
    The entire shaft is 16in long including the end that slips over the tractor pto. It is a 1in x 1in square shaft. The model is a john deere #39 sickle. thanks, brian.
  5. #5
    New Member
    Join Date
    Jan 2014
    Posts
    3
    azle tx
    ford
    I can get pics later. The half that's on the sickle has a hole slightly larger than 1in wide. The part I need slips into the existing shaft. It has to be 1in square and 16 in long with one end to fit the tractors pto,thanks brian
  6. #6
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,090
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    This place has the shafts in 2 different lengths(AH13088 12-5/16" & AH12488 15-11/16"s) that I found. You have to go through a participating equipment dealer to get the part.
    Attached Thumbnails Attached Thumbnails jd sickle pto shft-capture-jpg   jd sickle pto shft-capture-jpg
Similar Threads
  1. Replace PTO Shaft on Ford 501 Sickle Mower
    By macecase in forum Haying
    Last Post: 10-10-2013, 11:08 AM
  2. B7100HST - Replacing front drv shft+U-Joints
    By pacaron in forum Kubota Owning/Operating
    Last Post: 05-30-2010, 06:22 PM
  3. Deere #5 Sickle Mower PTO?
    By tobinator1959 in forum Attachments
    Last Post: 05-10-2006, 08:51 PM
  4. Sickle Bar 3PH PTO type sickle bar mowers
    By patrickg in forum Attachments
    Last Post: 09-11-2002, 01:11 PM
  5. Sickle Bar Sickle Mower for rear PTO
    By Steelfan in forum Attachments
    Last Post: 06-13-2002, 09:34 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
