Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Mar 2014
    Posts
    3
    Black River MI.
    New Holland TC30
    Default Rear Axle Seal on New Holland TC30
    I think I post this question in the wrong section before,it was in the New Holland section.
    My TC30 starting leaking rear axle oil, is this a big job to fix? Is there a place to find torque specs ?. Will I need special Tools. On a fixed income so I must try
    and fix myself if possible. Thanks for any input you have on this.
    Z
  2. #2
    New Member
    Join Date
    Mar 2014
    Posts
    3
    Black River MI.
    New Holland TC30
    Default Re: Rear Axle Seal on New Holland TC30
    All tore apart, can't get axle out? I see a snap ring and thinking its only for holding bearing. Took the lock nut off axle and remove 4 bolts off seal cover. Do I
    have to drive axle out? I know the outer bearing is bad ,a lot of movement at end of shaft. Should both bearing be replaced.
    Thanks Z
Similar Threads
  1. Rear Axle seal on TC30
    By zplugger in forum New Holland Owning/Operating
    Last Post: 03-31-2014, 07:36 PM
  2. Mowing Grass wrapping rear axle - NH TC30
    By BlueRanger in forum Owning/Operating
    Last Post: 11-18-2012, 12:28 AM
  3. New Holland TC30 Transmission/Rear Axle -- common sump??
    By paintpony in forum New Holland Owning/Operating
    Last Post: 08-19-2012, 09:26 PM
  4. rear axle seal
    By syarbrough in forum Parts/Repairs
    Last Post: 07-08-2012, 01:57 PM
  5. Rear Axle Seal
    By Eddie in forum Yanmar
    Last Post: 07-10-2006, 11:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
