Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    New Member
    Join Date
    Apr 2014
    Posts
    15
    Benton City, WA
    MF35
    Default Re: MF 31 Sickle Mower Refurbish
    Quote Originally Posted by Sodo View Post
    Agreed
    Is this pic "in use"? Or is it partially disassembled?
    I can't imagine how that could do ANYTHING but fold the weeds in half and jam them into the guard. The shearing edge of the section needs to slide directly on the guard below, to create the shearing action.
    What is causing the section to rise so far above the guard? Is the sickle 'track' full of weeds, lifting it up? Is the bar bent? Is there a block that rides ontop of the sicklebar keeping each cutter section down low against the shearing edge (that you may grind sharp) of the guard?
    Not in use, but installed for lack of any replacement guards. The sickle track is not full of weeds, but clean. Actually, it hasn't looked a weed in the face in three years!
    I understand the need for the section to ledger plate gap to be adjusted to around 10 mils, just haven't started trying to do anything with this yet. You're right...won't do anything but jam the way they are shown in the pictures.
    When I took those pics, I don't even recall for sure if I had the hold down clips set. I'm at the point where tomorrow I will first set the clips, then start adjusting gaps and hope for the best. It's hard to tell from the pics, but it looks like the gap was wedged, not parallel...as if the guards were loose and hanging down a little, or the cutter bar was tipped, ie, clips not set. I really don't recall. I mainly took those pics to show the wear on the ledger plates.
    Thanks for your comments!
    Optiker
  2. #22
    New Member
    Join Date
    Apr 2014
    Posts
    15
    Benton City, WA
    MF35
    See the picture of my "test drive" of the MF31 sickle mower, subject of this thread. I guess by the looks of the results, the process was a success, and even in time to stick with my mowing schedule. Schedule is important since I irrigate on a schedule, so have to work in a cutting between irrigation sessions, and also avoid any forecast rain - this time of year, there's always a good chance of getting it rained on, or blown away by high winds.
    I have to give credit where due. We're Christians, and there was a lot of prayer go into this refurbish project. In between my numerous mistakes and doubts, there were sprinkled a number of "coincidences" that resolved problems. Y'all know what a coincidence is, don't you? It's when God wants to remain anonymous!
    I only did a couple of swipes today since I had to spend the rest of the day trimming around sprinkler risers with a string trimmer - couldn't see most of the risers since the grass was so tall. Tomorrow is the big day when I'll finish mowing.
    Anyhow. I guess it's not the result in favor of Sodo since I won't be selling it to him for parts.
    Thanks for all of the replies and encouragement.
    I guess this will close this thread.
    Optiker
    Attached Thumbnails Attached Thumbnails -mf30-test-drive-jpg
  3. #23
    Gold Member
    Join Date
    Feb 2012
    Posts
    438
    Albion, Indiana
    1710 Ford
    Looks like it is working. how did it sound? Like it was working or chugging or did it cut real smooth? The results look good.
    BTW - serrated sections will work fine for this type of grass. We always went by the rule that the more flexible the stem that you were cutting the more you needed serrated sections to hold the stem from sliding away from the section. Stiff stems like a wheat grass or wheat or alfalfa it was best to use smooth sections where you could sharpen them. Different people have different theories though so use whatever works for you!
  4. #24
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    6,356
    Northern California-Tehama Co.
    2008 Mahindra 5525, 1964 MF-135 diesel, 1951 Farmall Super A, 1951 Minneapolis Moline BF, 1945 Oliver 60 Row Crop, 1949 JD B widefront
    Looks like that old mower is alive and well once again. Congrats.
  5. #25
    New Member
    Join Date
    Apr 2014
    Posts
    15
    Benton City, WA
    MF35
    Sounded great. One very slight bind when hand-turned that I couldn't find, but running, sounds pretty smooth.
    Thanks!
    Optiker
  6. #26
    New Member
    Join Date
    Apr 2014
    Posts
    15
    Benton City, WA
    MF35
    Yup! Hopefully, by the end of the day today, first cutting will be down.
    Thanks!
    Optiker
  7. #27
    Platinum Member Sodo's Avatar
    Join Date
    Apr 2012
    Posts
    717
    Seattle, WA
    Kubota B2710 & KX41-3v Excavator
    nice pic of cut grass…...grumble grumble.....well I'm glad someone's cutting grass….
    Be sure to grease the bearing at the forward end of the crankshaft. On my MF31 all OTHER bearings were in fine shape (lots of grease & obvious care/maintenance), But this forward bearing had the 'original factory grease' in it (nearby) and no other grease. There was a bolt in the grease fitting hole and it appears that the owner never greased the bearing. I suspect this bearing failure caused the wobble crank to shake so much that the heavy adjustable sheave (at other crank end) broke off.
    Note that it's a "special bearing" DISCONTINUED by MF & Agco. It's like gold ($76), don't let it go bad! (plus it's no fun to replace). The original 19mm wide bearing had a 4mm thick wheel-bearing type seal on it. I think I'm going to just replace mine with a sealed 6205 ($8) The 6205 is 15mm wide instead of 19mm original. I'll remove the inner seal so I can pump grease on thru.
    I talked with a knowledgable fellow at Nolts eqpt, Newville, PA, who said they had 2 rebuilt MF31s for sale and that they were a very nice, smooth mower. He said normally nothing goes wrong with the boxes, and the wear parts are all available.
    Attached Thumbnails Attached Thumbnails -mf31-mower-lubrication-jpg   -mf31-sk-88-bearing_pic-jpg
    Kubota B2710. Home-made 5x4 foot brush fork with quick-release stick rakes at front, 4-foot field mower, Massey Ferguson #31 sickle mower. I use it for landscaping, scrape up logging slash, feed a small sawmill, take out bushes, dig waterbars, fix the road, mow snowboard runs, screw around.
  8. #28
    New Member
    Join Date
    Apr 2014
    Posts
    15
    Benton City, WA
    MF35
    Hi Sodo...
    Sounds like you're making progress! The metal plate showing grease points on the wobble box is nearly gone. Fortunately I bought a manual years ago when I bought the mower. All the zirks are there, and got a good shot before I started it up yesterday.
    Got my hay down just in time to have it rained on! Oh well...who hasn't been there...especially you guys from the west side!
    It's been so long since I've mowed, I've had to relearn a bunch...like just how far out 7 ft really is. I only knocked over one sprinkler riser though. And, I really appreciate the break-away...managed to use it a few times.
    Lord willing, and dry tomorrow, maybe I can think about raking on Saturday if the top dries out a bit tomorrow.
    Good luck on getting your 31 running!
    Optiker
Similar Threads
  1. sickle mower/disc mower conditioner
    By tw30 in forum Owning/Operating
    Last Post: 04-18-2010, 10:34 PM
  2. Oil & Fuel Refurbish Ford 3000 GAS or Sell & Replace?
    By jascott in forum New Holland Owning/Operating
    Last Post: 03-20-2008, 12:20 PM
  3. 1966 MF135 refurbish question
    By shadoe in forum Massey Ferguson Owning/Operating
    Last Post: 06-06-2005, 08:23 AM
  4. How do you refurbish an old implement?
    By Laminarman in forum Projects
    Last Post: 04-12-2005, 12:10 PM
  5. Question for those who refurbish, repaint
    By SteveM in forum Yanmar
    Last Post: 03-22-2004, 04:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
