Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Jun 2014
    Posts
    3
    willow spring, NC
    john deere 4300
    Default john deere 4300 compact sync reverser problems
    My 2000 deere 4300 sync reverser compact tractor forward - reverse lever is moving when clutch is pressed or released. I noticed they are both on the same shaft in the trans. but this does not seem normal I just bought this lemon of a tractor and trying to work out all the bugs. thans for any input.
  2. #2
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,082
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    Default Re: john deere 4300 compact sync reverser problems
    Some pictures would really help. Guessing there is a solid shaft for one function, probably the clutch, that runs through a tube/shaft, which is probably for the reverser function. Just sounds like a lack of lube there, and it's binding/gaulded some. Try looking for a grease zerk(s) on the cross shaft. If that is the case, it's quite common on Ag. tractors.
  3. #3
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,007
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Some lubrication on brgs(parts key 31) might help.
    Attached Thumbnails Attached Thumbnails john deere 4300 compact sync reverser problems-mp23112________un29aug00-gif
Similar Threads
  1. JD 4300 Sync Reverser Transmission Problem
    By JD004300 in forum Parts/Repairs
    Last Post: 02-21-2017, 10:46 PM
  2. John Deere 4300 sync reverser
    By poppabear1089 in forum John Deere Owning/Operating
    Last Post: 09-06-2012, 07:35 AM
  3. 4300 / Sync Shift - Power Reverser
    By Whitey in forum John Deere Owning/Operating
    Last Post: 05-21-2009, 10:34 PM
  4. 4300 Sync Reverser Transmission
    By Mike_H in forum John Deere Owning/Operating
    Last Post: 10-23-2008, 09:20 AM
  5. Sync Reverser vs. Power Reverser- Is there a difference
    By blaplante in forum John Deere Buying/Pricing
    Last Post: 09-05-2007, 09:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
