Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Jul 2014
    Posts
    2
    VA
    1985JD 450D buldozer
    Default 1985 JD450 D Buldozer will not shift into another gear while running.
    If you get this dozer in between gears while trying to shift the clutch will not release and allow the gear change. Can the clutch be adjusted or is some other maintenance required?
  2. #2
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,086
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: 1985 JD450 D Buldozer will not shift into another gear while running.
    Clutch pedal free travel can be adjusted but it sounds as if clutch plate is stuck.
  3. #3
    New Member
    Join Date
    Jul 2014
    Posts
    2
    VA
    Does this require eng removal to correct?
  4. #4
    Join Date
    Jan 2007
    Posts
    7,086
    Coyote Flats,Tx
    Try blocking clutch pedal down,start engine and get engine up to operating temperature to see if clutch plate will free up. Another possibility is a broken pressure plate bolt bolt which would require engine R&R.
Similar Threads
  1. Gear Shift
    By markh1 in forum Chinese Tractors
    Last Post: 10-11-2011, 03:42 PM
  2. JD 970 won't shift into gear
    By MidTNDawg in forum John Deere Ag Tractors
    Last Post: 09-02-2011, 10:15 PM
  3. Buying Advice Gear shift vs. HST
    By jmpbuffalo in forum Kubota Buying/Pricing
    Last Post: 05-18-2011, 11:19 AM
  4. Floppy gear shift
    By lambs in forum Massey Ferguson Owning/Operating
    Last Post: 02-26-2011, 12:05 PM
  5. gear shift on a 475DI
    By casinocop40@excite.com in forum Mahindra Owning/Operating
    Last Post: 08-03-2007, 10:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
