Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Jun 2014
    Posts
    3
    UK
    Countax s1300
    Default Briggs and Stratton 286707 uneven running
    I have a Countax ride on Tractor here in England. It is fitted with a Briggs engine reference 286707 which has a gravity fed LMT Walbro Carburettor. The engine starts easily but at normal temperature and maximum revs it runs for about 2 minutes then 'splutters' for a second or two then runs normally again then the cycle is repeated. I have fitted a new spark plug RJ19LM and use new fuel. The air cleaner is good and I have washed and oiled the prefilter as per the instruction book.
    Any ideas what might be causing this problem please?
    Thanks in advance for any help you can give.
  2. #2
    Join Date
    Mar 2002
    Posts
    718
    Central Arizona
    YM1500D
    Default Re: Briggs and Stratton 286707 uneven running
    Sounds to me like it is time to dig into the carburetor. Maybe a sticking or incorrectly adjusted float valve. Might want to check the fuel filter first. Let us know what the problem is when you get it fixed. We might learn something.
  3. #3
    Super Member bindian's Avatar
    Join Date
    Feb 2007
    Posts
    6,971
    Willis, Texas
    Mahindra 6520 4WD
    I don't remember the model numbers. Is this a twin cylinder Briggs? The older twins had a diapharm fuel pump. The diapharm might have a hole in it. I once overhauled my Dad's 18 horse twin Briggs on his Gilson lawn tractor. Sometimes it just ran better with a little choke. If you do rebuild the carb, have it cleaned in an ultrasonic parts cleaner. Also, as I remember, the governor linkages on the twin are complex. Make sure it is working right.
    hugs, Brandi
  4. #4
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,193
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    I second a good carb. cleaning. Be sure and remove the discharge nozzle, and check to make sure the cross drilled holes are clean & open. A single wire from a wire brush, or strand of copper wire from a section of automotive 10-12 ga. wire make a good cleaning tool.
  5. #5
    Super Member
    Join Date
    Dec 2007
    Posts
    5,639
    Canada
    Ford 3930
    A second vote for replacing the fuel filter, if it has one. Take a peak inside the gas tank with a good flashlight, checking for debris in the bottom of the tank, and also water contamination. I've seen lawn equipment that is stored outside have globs of water sloshing around in the bottom of the tank.
    As posted, the carb may have to come apart for parts replacement/adjustment. Before doing that, if you haven't already, try dosing at the recommended levels with a good gas treatment/carb cleaner.
    Seafoam is commonly available here.... but I'm not sure what is stocked in the UK.
    Sea Foam Motor Treatment (Seafoam)
    P.S. - I'm meaning add to the fuel tank, and run the engine. Seafoam (or equivalent) can be used other ways, but would likely be the most help added to your gasoline.
    Best of luck. Rgds, D.
Similar Threads
  1. Briggs and stratton Engine popping while running?
    By chad22 in forum Parts/Repairs
    Last Post: 02-25-2014, 09:42 AM
  2. Old Briggs and Stratton
    By Kegomatix in forum Oil, Fuel & Lubricants
    Last Post: 02-07-2014, 08:35 PM
  3. How about a Briggs and Stratton forum?
    By alchemysa in forum News/Feedback
    Last Post: 05-06-2013, 02:34 AM
  4. 19.5 hp briggs and stratton
    By Bwgad96 in forum General Lawn & Garden
    Last Post: 06-28-2012, 10:17 PM
  5. Ruff Running Briggs & Stratton Twin
    By Johnypat in forum Parts/Repairs
    Last Post: 10-23-2010, 09:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
