diamondjfarmwv
Member
Good morning all.
My 1968 Farmall 140 is losing oil pressure. Upon start-up, the oil pressure needle centers in the dial reading 0 to 75 lbs. After running the tractor about 10 minutes, the pressure starts to bleed off. After about 20-25 minutes, the pressure needle drops to the first mark above 0 (which I assume is 20 lbs) and the radiator overflow tube just below the cap begins to drip (which I assume is the engine overheating). There is no erratic jumping of the needle, like when an oil pump in a vehicle is going bad--just a slow, steady, even drop in pressure. When I bought the tractor (my first) about two years back, the owner included a gallon of Valvoline 20w50 and a Case IH filter. I changed the oil and filter last summer, after some spring plowing and disc harrowing on 3 acres of compacted clay loam soil. I ran the tractor long and hard from early April through late May this year--probably 50+ hours. I purchased a new filter earlier this week at a local tractor/farm supply store, and the owner suggested using 30w non-detergent, which I did. Yesterday, while cutting weeds in the pasture with a sickle bar, I noticed that I got about 5 more minutes before oil pressure drop and overheating. I'm thinling a new oil pump. What do you fellers think?
