Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
  1. #11
    Elite Member
    Join Date
    Mar 2002
    Posts
    2,898
    Iuka Mississippi USA
    3550 Fard Backhoe and a 1948 Farmall Cub,
    Default Re: FEL for a Ford BN
    Deerlope, Ive seen the Fransgaurd ones I make a few of them here for olks that cant find their dealers. The old Ford one I bought it mechanical hinges the boosters just push the 3 point up past its normal lift height. I ll post a few pics after i resize them.
  2. #12
    Elite Member
    Join Date
    Oct 2000
    Posts
    3,061
    Windham County, Conn
    Ford 2120 , New Holland TN75D, Hitachi UH083LC Excavator
    I grew up on a Nursery with a 8N with a loader. We had it for many years. The bucket was probably about 48 to 60". I remember the tube frame of the loader was the reservoir for the hydraulic fluid so it may have had a second pump. It worked fine as a loader and I loaded many truck loads of loam and peat with it. I'm looking for a 8N for my collection.
    Andy
  3. #13
    Join Date
    Jun 2003
    Posts
    1,649
    Northern, New York
    Kubota L3830 03: RTV 900
    TaylotTractorNut
    Go to www.valbysales.com and select PTO shafts then scroll down to rear mount loaders. Makes for some good reading.
  4. #14
    Elite Member
    Join Date
    Mar 2002
    Posts
    2,898
    Deerlope Thats the one I copy lol Tyey work good on an older tractor to because you can use an eletric pump.
  5. #15
    Super Member
    Rest in Peace
    frank_f15's Avatar
    Join Date
    Mar 2001
    Posts
    6,033
    BUFFALO ,NEW YORK AREA
    kubota b2400- R4 tires
    up to 3 years ago i had a ford 2n ( almost the same as 8n) and it had a fel on it, this fel was kind of unique for this trator as it had a power dump(most had a mechinical dump) this allowed for scraping and a sembelemse of backdragging, although there was no down pressure. was a lot better than some of the older units i had but it sure was heavy and stuck way out. because of the weight and the long distance it stuck out it had a tendency to off load the rear end, especially if u got he front wheels going down hill. i know i have some pics of it . i will find them and post them in a few min. hopes this helps
  6. #16
    Super Member
    Rest in Peace
    frank_f15's Avatar
    Join Date
    Mar 2001
    Posts
    6,033
    SORRY I HAD TO FIND THE PICS AND SCAN THEM and resize then for the board , but here they are, gives u an idea of what was/is avalible for that tractor
    Attached Images Attached Images
  7. #17
    Super Member
    Rest in Peace
    frank_f15's Avatar
    Join Date
    Mar 2001
    Posts
    6,033
    this is not a great pic. but will give u an idea of what i meant when i said they sitck way out there, sure beat the alternitave [img]/forums/images/graemlins/grin.gif[/img]
  8. #18
    Super Member
    Rest in Peace
    frank_f15's Avatar
    Join Date
    Mar 2001
    Posts
    6,033
    as u can see they made the superstructure on that fel quite heavy. but it did work and work quite well. sorry i had to get rid of it. was a nice tractor,
  9. #19
    Join Date
    Jun 2003
    Posts
    1,649
    Northern, New York
    Nice pics Frank, I do remember those old FEL's mostly used by small contractors. But I am sure if someone wanted a good all hyd. one that Allied has one that would fit it.
  10. #20
    Super Member
    Rest in Peace
    frank_f15's Avatar
    Join Date
    Mar 2001
    Posts
    6,033
    GLAD TO SEE someone else remembers those old things, where abouts in northern ny are u? used to do quite a bit of hunting around the ST. REGIS FALLS AREA.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
