venison
well, guys, I think I have really messed up bad... When removing my injection pump, I did not realize that the gear it bolts to would be loose in the case. One of the hazards of being inexperienced...
So now I have reinstalled the pump, but while reinstalling, I realized that I have no idea if the gear teeth have aligned correctly or not. If it is off, I don't think it would be off by more than a tooth, but I don't have any idea how bad that could be.
If I attempt to start the motor and my timing is off, am I looking at potential catastrophic damage? I figure if it is way off, it won't start at all, but what if injection/combustion occurs early while cyl is compressing? that could be really bad couldn't it?
I am hoping to avoid having to pull the timing cover, but there isn't any other way to be sure the gears are aligned correctly right? Plus it would need to be at No1 TDC and I don't know how to get it there....
ugh
1990 Perkins AT4.236 w/ Lucas CAV (Delphi) rotary inj pump
MF 60HX-T
ugh
MF 60HX-T
