DR7710
I bought 1989 Ford 7710 and it was running great. I bought all new filters, but before I could replace them it quit running. Started out as a sluggish throttle, but then one day it would not start after I turned it off. I pulled the sedimenter and fuel filter and they were about half full of a thick sludge. So at that point i decided to pull the tanks too and clean the whole system. The tanks were in good shape but about a half inch of the same junk in the lower tank. Cleaned the tank and lines and put on the new filter. I did not do anything to the lift pump or injector pump. Filled the tanks with new fuel and started priming the system. I thought I had finished priming it this past weekend, but still wont run. It will act like it is starting but die in about 3 to 5 seconds. It actually ran about 15 seconds at one point but died then as well. With just turning the engine over I'm getting light puffs of white smoke. When if fires and acts like its going to run I getl big puffs of black smoke. So my question is, does it sound like I still have air in the fuel system or does it sound like I have another problem going on?
Thanks,
Doug
Thanks,
Doug
