Chaostamer
- Joined
- Jan 28, 2012
- Messages
- 74
- Location
- Viola, ID
- Tractor
- Mahindra 3215 w/ FEL & Kubota M6040 w FEL
I have a Kubota M6040 with loader and cab. I bought it this spring (165 hrs on it). The thing worked well up until this weekend. I jumped in, started it up, let it warm up and then headed out of the shop. I slowly backed out of the shop and started to go around a corner and realized that there was no upper RPM. I could max it at 1900 at best. It got to a point where it would barely run. I let it sit for a little bit as I got Diesel 911. Put about 4 oz in (temp was only 42 so this should have not been my first thought but I am learning). Tried again and got the 1900 RPM line again but not for long. Barely limped back to the shop. On the advice of my friend I pulled fuel lines off as a precheck before changing the fuel filter. I pulled the line going into the filter and had my wife turn the key and crank the tractor. The initial trickle of fuel turned to nothing. So I backed up to just before the water separator (line coming in from the tank) and same thing. I thought then it might be a fuse issue. I checked the fuses under the steering wheel and there is nothing there that would relate to a fuel pump (I didn't check all the fuses because they didn't seem to line up with fuel issues). Any ideas what is going on here? My skills and time are limited but would like to try to fix this thing is possible.
