bcribb
Member
I have a Farm Trac 390HST tractor with a 4 Cylinder Mitsubishi engine.. I can't get the engine to start.. Things I have tried are, replacing the fuel line to the tank from the lift pump, blowing the line clear with air from the lift pump to the tank.. Installed a new lift pump.. Checked the fuel shut off solenoid.. Checked the glow plugs.. Checked compression.. Loosened each individual line from the injector pump to bleed air out.. Loosened each individual line to the injectors to bleed air out while cranking engine.. Checked fuel level in tank. Checked for water in fuel.. When I remove the lines from the injector pump and turn the engine I seem to get a good flow. The stream goes up about 6 inches out of each port on the injector pump.. When I hook everything back up and and turn the engine to bleed the air again from each line, when I stop cranking the engine and wait a few minutes I can see air coming from the injector pump supply line at the pump ( clear plastic line) that comes from the lift pump. The supply line from the lift pump has a hose going to a 2 way coupler on the injector pump. From the coupler one line goes to the pump and the other back to the tank. Also on the same line that goes to the tank is a small plastic T that a hose from the injectors taps into. I've read that that line is a return line of some sort from the injectors to keep them cool, .. I sure would like to find a solution to this problem so I can get this tractor going again.. Its been down for 2 weeks and I can't afford to take it to a dealer and plus its a long ride.. Any ideas or suggestions would be appreciated.. I can get pictures of what I have if needed.. The radiator is off and everything is easy to get to.. Thanks for reading...
Barry
Barry
