Hi Dave,
I think the battery has been draining because of power being drawn by the glow plugs. The orange light on the dashboard comes on intermittently when the tractor is running, it does not light up when I start the tractor in warm weather (the temp in the drive shed is about 25C at the moment) I've tried the tester and it glows as expected across the battery and when hooked up to the starter. No response from any of the four glow plugs when engine off, key turned or engine on. The plugs (unless I'm looking at the wrong components?) have small nuts on top and are joined together by a metal strip that seems to have a coating of plastic insulation between the plugs. I've used the probe at the top of each small nut and further down the plug just above the larger hex nut.
Your thoughts would be greatly appreciated.
Cheers Luath.
Cheers Luath.
