Paul75
I'm new to the forum and hoping someone can give me some ideas about the issue I'm having. I own a New Holland 1920 and I've started having trouble shifting gears at the column. I thought it might be the clutch out of adjustment or possibly going bad, but it will go into gear easily sometimes and then not at all others. The clutch seems to let out fine and once in gear the tractor takes off fine. Is there a chance it is gear synchronizers going out and not the clutch? That is if it has synchronizers? When I called the local NH dealer the service guy said clutch, but I知 not sure since the clutch seems to be engaging and allowing the PTO to function fine. The tractor is a 2000 and has 2005 hours on it. Thanks in advance for any thoughts and advise.
