WileyG
My throttle on my YM300 has become inoperable and the tractor only runs wide open in a run away state. I have taken the throttle linkage loose from the lever on the injector pump and there is spring tension on the lever from inside the crank case but it does nothing to control engine speed. This evening I'm going to remove the inspection plate and see if I can determine what has come loose. What should I be looking for in there and can I resolve this problem thru that opening with the plate off?
