Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Oct 2015
    Posts
    3
    Grandview, TX
    New Holland TC21D
    Default Electrical problems
    My 2000 New Holland TC21D stop running, battery is good ignition switch tested okay, when I turn the key on I get no dash board lights. I am sure it is a relay just not sure which one or how to locate it with out a schematic. Any*ideas? Thanks
  2. #2
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    6,733
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: Electrical problems
    to TBN neighbor from Coyote Flats,Tx
    Have you cleaned tightened all FOUR battery cable connections? Sometimes ground(negative) battery cables connections are overlooked only to determine they were the problem.
    Jim
  3. #3
    New Member
    Join Date
    Oct 2015
    Posts
    3
    Grandview, TX
    New Holland TC21D
    Quote Originally Posted by Tx Jim View Post
    Jim
    TxJim, thanks for your replay. I changed the negative cable and cleaned all the one you referenced. I talked to NH this morning and they said it might be a linked fuss located near the starter but I can't find the dang thing. The search goes on. Again thank you.
  4. #4
    Join Date
    Jan 2007
    Posts
    6,733
    Coyote Flats,Tx
    My next guess would be the fusible link that Messicks stocks 6(six) of which indicates fusible link is a high turnover parts item.
    Attached Thumbnails Attached Thumbnails Electrical problems-capture-png
Similar Threads
  1. Electrical problems
    By stephen1956 in forum Parts/Repairs
    Last Post: 10-03-2015, 07:12 AM
  2. More electrical problems
    By JasonMI in forum Parts/Repairs
    Last Post: 01-18-2012, 07:45 AM
  3. Electrical Problems
    By steviele in forum Parts/Repairs
    Last Post: 03-08-2011, 05:05 PM
  4. Electrical problems
    By The Dougster in forum Rural Living
    Last Post: 11-16-2009, 10:03 PM
  5. Electrical Problems
    By MT Montana in forum Montana
    Last Post: 08-19-2007, 08:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
