Thanks for the replies guys, JD says the injectors are trash, so I have to replace them anyway
So, Yes pump has four line, there is no electrical to the injectors. There are low pressure return lines on each injector. On the fuel filter itself, there is a shutoff, and other components as you listed. The engine will shut down after the shutoff is turned, but it does take a little while.
The solenoid operates correctly/the same, in or out of its location, or hooked up independently to another battery. The video in post #8 shows the injection pump when the key is being turned off/on. I was told by an expert that the solenoid rotates the plungers, and this turns the fuel off/on. He was quite stunned and stumped to see the vid of the plungers rotating, and knowing that the tractor would not turn off. You can see in the video the plungers are clearly rotating, and I might add they rotate freely and easily by hand, and they rotate the same wether the tractor is running or not.
Now this video is one that I saw that helped me understand better how it works https://www.youtube.com/watch?v=w9jMvJZwRuE
So, by looking at this, and knowing the plungers should be rotating to the full bypass position would lead me to believe my previous theory, that enough fuel is still reaching the injectors (and they are allowing it past) to keep the engine running. Either that or the bypass circuits are clogged, but if that were the case, the throttle would not operate correctly. I honestly haven't looked at the exhaust, but it was putting out some pretty black smoke when running. I have kept an eye (or nose) on the oil, and the fuel doesn't seem to be getting in there.
Thank you guys again for the input. I won't be doing anything else until I get some injectors any way, and can get the tractor back together.
Assuming:
The fuel pump has four lines coming off of it. Each line goes to an individual injector. There are no electrical wires to the injectors.
There is a low pressure line from the injection pump that discharges to the fuel tank.
On the fuel line there will be fuel shut off valve , then sediment bowl then on to the manual prime pump and thru the fuel solenoid into the injection pump.
If so: if the fuel supply is closed of at the tank the engine should shut down. No fuel. If the key is turned off the fuel solinoid should close and stop engine.
So, with the key shut off and engine running close the fuel supply at the tank. The engine will run for a bit but will shut down. If that happens it takes the injectors out of the problem area and places it in the switch - solinoid control. For solenoid control it can be removed and checked with the key while connected to the wiring harness. If the solenoid still does not work remove frame wiring harness and very briefly apply 12 volts. If it then works go after back to the relays, fuses and thermistor if it has one. After that it's the switch. Remember that a faulty wiring connection or switch contact could be the problem.
the injectors may need servicing but unless they are under individual electronic control they are not your problem. If they stick open fuel should show up in the exhaust manifold and start leaking out.
