SeaBiscut
- Joined
- May 11, 2010
- Messages
- 7
- Location
- Northeastern Pennsylvania
- Tractor
- Ford 1715 and Kubota B3200
Ok well here is my problem.
Kubota B3200 with LA504 loader
I was putting on my loader this afternoon. I put the left pin in, then I was going to put the right pin in but I was unable to get the holes to line up. Then I looked down where the lower arm sits in the cradle and noticed that the left side was not in the cradle. I can not get the pin out now. As I was trying to realign everything the loader kept going left. Now the loader is crooked. I do not think that I damaged anything except for breaking the headlight lens cover. The loader hydraulic fitting hit the lens. So I need some advice. I think the first thing that I need to do is pull loader straight with the tractor using a comealong or the neighbours loader. As I lower and curl the bucket so that it rests on the dismount skids I think I will need to keep pressure with the comealong/loader. Do you guys think this will work? Have you ever had this happen to you? I am attaching two pics of the lower bracket so you will know what I am talking about. Thanks
