Results 1 to 9 of 9
  1. #1
    Join Date
    Feb 2004
    Posts
    53
    Texas
    Kioti LB1914
    Default 14" Notched Disk?
    I have a hipper that has 2 busted disks. They're 14" outer diameter, and they fit on a 1" round axel. I haven't had any luck whatsoever finding replacements for them.
    Anyone know where I can find disks that size? I bought the implement used, and there's no markings as to brand on it.
    Sam [img]/forums/images/graemlins/confused.gif[/img]
  2. #2
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,726
    Nova Scotia, Canada
    Default Re: 14" Notched Disk?
    Have you tried some farm impliment dealers. Naby times thinks such as dics are generic and can be interchanged.
    Egon
  3. #3
    Join Date
    Feb 2002
    Posts
    996
    My guess would be that they are actually 16" and have 2 inches of wear.. I have been at this along time and have never seen a 14" disc listing but I have seen disc worn as much as 5". I guess these could be fairly old and before time but I still think I would have seen that size in a catalog someplace. 16" with a round 1" hole are fairly common.
  4. #4
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Like the others mention.. they were probably larger discs.. Unless you are changing all of htem.. try to find the closest to match.. as for round vs square... you could alwas make a square disc hub into a round one with a file or plasma cutter.. torch..arc welder with chamfer rod. etc
    I've fixed a disc or two out of need like that before. Usually I've welded in a proper sized flat washer for better fit.. etc
    Soundguy
  5. #5
    Join Date
    Feb 2004
    Posts
    53
    Texas
    Kioti LB1914
    All,
    Thanks for the help. I think they're really 14" disks. since they show little wear on them, and they're just hilling already loose soil.
    I think there's enough clearance to easily put 16" disks...but that would mean buying 8 disks rather than just 2.
    If anyone has any pointers for someplace to look, I'd be grateful.
    Thanks,
    Sam
  6. #6
    Super Member Inspector507's Avatar
    Join Date
    Mar 2002
    Posts
    5,905
    Central Ohio
    Might try this page from Agri-Supply
    I only found 14's to fit a square axle though
    800-345-0169 try giving them a call.
  7. #7
    Join Date
    Feb 2004
    Posts
    53
    Texas
    Kioti LB1914
    Inspector507,
    Thanks for the pointer. I have their paper catalog, and they only list 16" or higher...I hadn't looked at their web site though.
    Thanks!
    Sam
  8. #8
    Approved Advertiser
    HayDR's Avatar
    Join Date
    Oct 2002
    Posts
    1,896
    Johnson City, TN
    JD 2040,2240, 2355, 2755, 4055
    sl3uth,
    Agri-Supply should have the disc but also realize 14" is not in demand like the larger disc. The problem you might have is if you do not find them quickly you likely will not find them at any price. THe disc in stock now ar 1/3 the current price of disc blades because the increase in steel prices.
  9. #9
    Join Date
    Feb 2004
    Posts
    53
    Texas
    Kioti LB1914
    </font><font color="blue" class="small">( The problem you might have is if you do not find them quickly you likely will not find them at any price.)</font>
    That's been running through my mind quite a bit.
    Is there a rule of thumb for calculating the separation of disks given their diameter? I might need to go up in size...but I want to make sure that it still works.
    The clearance is there vertically for 16" disks, but I am concerned about keeping the functionality of the implement. Since this is a "hipper", the disks are set at a fairly steep angle. Each side has a 4 disk section that is 24" across. Due to the angle, this 24" section fits inside my 16" tires tracks. If it still works, then I'll bite the bullet and get larger disks...any ideas?
    Thanks,
    Sam
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
