By mistake poured 2 quarters of diesel motor oil in the transmition reservoir. There are some opinions that I should not be worry, what do you think? How screwed am I?
/ ADVICE NEEDED: poured motor oil in the transmition reservoir in a kubota tractor
I think the weight of the oil being a problem would be secondary to the different additives in the two oils.
With that said, I don't think you've contaminated it with enough to worry about. After all, you only added 5% to the total volume. On tractors with rear remote couplers they eventually get contaminated with that much variety of oil by hooking/unhooking to different hydraulic implements. Especially when you borrow your neighbors implements that have 30 year old oil in the cylinders. That mixes with your high dollar Synthetic oil.......
Get a firm grip on your money when you go to buy the oil and filters!!!! My M9540 holds 16 gallons. I used Kubota SUDT2. Right around $520 for the oil!!!!!!
I checked on other brands of comparable oil and wasn't going to save much if any. So went with Kubota brand. Good thing they don't need changed often!!!!
I'll run this oil quite awhile. Probably change filters once a year and top it off.
I wouldn't worry about it. Think hydraulic fluid is from highly refined 100N. Most motor oil comes from mostly 150N (next heavier cut) but has a bunch more additives. Our mechanics in the refinery used to use normal high quality motor oil in the hydraulic circuits that controlled the speeds of our horizontal dewaxing filters. You 10x30 oil would have about the same viscosity at cold temps as your hydraulic oils.
