Hooked_on_HP
I have a b7610hst with around 1000 hrs on it. I started to back it out of the garage and it started moving then it paused for a couple of seconds then it started moving again . Now is where things got bad. It stopped moving again and started making a loud squelling noise out of the bell housing. If I push the clutch in the noise goes away. I checked and the shaft that goes from the bell housing to the main hydro pump is not spinning. It just chatters. It is full of fluid and I did try replacing the hyd filters. I am hoping it is something simple like a striped clutch shaft. My service manual doesn't give a good pic of what is in the case that bolts to the bell housing. One pic shows 3 shafts and gears and another shows like the outline of a pump. Any one had one of these apart. I am in the process of splitting the tractor now.
Bill
Bill
