I opened up the fill hole and added more gear oil to the gear box on my Woods Brushbull. Over tightened when I closed it up and it snapped off leaving part of it threaded in top of gear box. Any tips on getting the broken piece out?View attachment 471568
Yep, clean it up real well then lay a nut centered on top of the broken stub. Weld the nut to the stub though the hole in the nut. That will give you something to wrench the plug out with. I would say drill and ez out but you'd risk getting shavings and chips in your case.I opened up the fill hole and added more gear oil to the gear box on my Woods Brushbull. Over tightened when I closed it up and it snapped off leaving part of it threaded in top of gear box. Any tips on getting the broken piece out?View attachment 471568
