jpkachur
Hello all,
I am working on a 1975 John Deere 2130 that has loose steering. I have completely rebuilt the front bell end and removed all play in that section. The long drag link is solid and is fine. The heavy drop down linkage just inside the housing near the clutch that has tapered splines which goes on the end of the power steering shaft and connects down to the main drag link is worn and you can see the main power steering shaft turns a bit before it engages the other side of the splines on the heavy link. This causes about 4" of play at the front tie rod ends. I have purchased the new heavy link and am wondering how to replace it. If you remove the small round hole cover and remove the bolt, is there enough room between the end of the power steering shaft and the housing with the small round cover plate to pull the heavy link back and slide it out and down? I am hoping it is but don't know. If so, it will be easy to replace and just slide the new one up and in and secure it with the bolt to remove all this play in the steering.
The tech manual does not mention how to do it either. My tractor is up in the bush and I want to ensure I have the right tools to tackle this before I head up to do it.
Thanks!
Jason
Thanks!
Jason
