kubotal4200
I've got a JD 3010 from around the 60's its one of the first JD's with power steering.. and that power steering is going out so I need to replace it but to remove it I have to first remove the front end suspension/axle system.. as the power steering box sits directly above all this
I was goin to do this by simply removing the tie rods as their connected to the mainframe independent of the rest then unbolt the whole wheel assembly and use a jack to lower it down while the rest of the tractor is jacked up.. but then the nightmare begins I cannot believe tie rods can be this difficult to remove I have a propane torch a acetylene torch several jacks and some heavy pieces of steel all of which hasn't managed to budge the tie rods one 16th of an inch...
The yellow thing in the picture is part of a hydraulic jack for removing stuck duallies.. It has a 2' foot long jack arm that I was standing on to get it to pump anymore. still didn't work I couldn't take the torch to that one because its too greasy..
the other one is at an angle but I can take the torch to it and I've had it glowing red and just beating the **** out of it and it doesn't budge.... is there something im missing here??? because I'm about to cut it out as necessary and then weld it back together
