Need help with Dad's tractor - Ford 3610
   / Need help with Dad's tractor - Ford 3610 #1
txdon
Super Star Member
Central Texas
Kubota M6H-101
While mowing with my Dad's Ford 3610 the left from tire turned the wrong way. When I lifted the tire off the ground with the FEL the tire fell off. Is this called the spindle axle assembly? How do I go about repairing it?
   / Need help with Dad's tractor - Ford 3610 #2
   / Need help with Dad's tractor - Ford 3610 #3
Same thing happened to our 3910. Replace the spindle. I also got new bearings and bushings at the time. Hardest part is removing the steering arm from the broken off piece of spindle.
   / Need help with Dad's tractor - Ford 3610 #5
We had that happen to our Jubilee and we had it welded and turned down on a lathe. Done remember what it cost, it was many moons ago. Hope it goes well. Ed
That is exactly right.
   / Need help with Dad's tractor - Ford 3610 #7
That's a pretty hefty shaft to break in 2 like that. Wonder what caused it?
   / Need help with Dad's tractor - Ford 3610 #9
I just made that same repair to a Ford 3600. Pretty easy, the hardest thing was jacking up the tractor with a loader on the front. Learn how to check/adjust wheel bearing play. It will save you issues down the road.
   / Need help with Dad's tractor - Ford 3610 #10
Hint..."Made in China"
The original OEM spindle was probably US/UK made. I have repaired a few of those in the last few years and most aftermarket spindles were made in China or India.
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
A1 MIST SPRAYERS RESOURCES TITAN X LOT IDENTIFIER 80 (A53084)
A1 MIST SPRAYERS...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
