Johndeere3720
Padawan Tractor Learner, Advertiser
- Joined
- Mar 14, 2009
- Messages
- 6,526
- Location
- NW Oregon
- Tractor
- Bobcat T62, MT55, E42R, E10, John Deere 4100
I haven't posted here in quite a while but this last week I picked up a Hinomoto E150D with a seized engine as a project. The story I got from the seller was that the previous owner had used this tractor for 20 years to mow his field. He parked it in his machine shed for about 3 years and when he went out to start it it would not crank, the starter would engage but not turn over the engine. Since lately I have been doing mainly electrical and hydraulic work I figured a powertrain related project would add some variety to my project list. After getting the tractor home and putting in a new battery I encountered the same issue, the starter will engage but not spin over the engine. I have tried to turn it over by hand from the crank with no luck either. At this point I have pulled the glow plugs / injectors and filled the cylinders with ATF. The fuel tank on this tractor was full and smelled more like alcohol then diesel. Also, the number 2 injector was covered in soot whereas the number 1 injector is clean. So right now I have a couple options. If I cannot get this tractor unseized I can rebuild the engine or buy another used S88 Toyosha engine if I can find one fairly locally. Any advice as to where I can locate a service manual and parts for this tractor?
