Results 1 to 10 of 10
  1. #1
    Join Date
    Jul 2003
    Posts
    49
    Lynchburg, VA
    Kubota L4300 DX
    Default $56.95 for a toolbox?
    Like the rookie tractor operator I am, I left the top to the underseat tool box open on my kubota L4300. I'm a fairly large man and so when I sat on the seat...crunch! I didn't even know I did it.
    Anywho, I called my dealer for a new one and he said "That'll be $56.95 plus freight and tax." Jeesh, this thing is made of thin sheet metal and can't cost them more then $5 to make.
    Dumb mistakes can sure be expensive.
  2. #2
    Super Member Bob_Skurka's Avatar
    Join Date
    Jul 2003
    Posts
    7,503
    Default Re: $56.95 for a toolbox?
    Big_A . . . for future reference, when you post something like this, you might want to start out the post with:
    "well it didn't happen to me, but my neighbor did . . . "
    That way we all know that it wasn't REALLY you, it was that other guy. And by the way, we all do things like this. Hopefully only ONE time.
  3. #3
    Gold Member
    Join Date
    Oct 2003
    Posts
    465
    Northern California
    New Holland TN70S
    Any chance you can replace the box with something else that's cheaper and probably better?
  4. #4
    Join Date
    Jul 2003
    Posts
    49
    Lynchburg, VA
    Kubota L4300 DX
    Hey mahlers, I was thinking the same thing. A quick trip to Northern and I may come back with a better item.
    Hey Bob, did I say that was me? I meant "This guy at work"...yeah...that's the ticket! [img]/forums/images/graemlins/grin.gif[/img]
  5. #5
    Join Date
    Aug 2002
    Posts
    872
    northfield connecticut
    gradall g3r excavator, kawasaki mule 2500,ford 8000,and a 1936 caterpillar road grader
    well i dont know what exactly the box looks like, but can you unbolt it and take it out and spend some time with a hammer and some blocks of steel and flatten it out? might not come out perfect but would be functional. last year at work i was working on a machine and had the 3/8 socket set sitting on the floor, its in a metal box about 3 x 5 x 16 inches, well somehow it got bumped under the forklift and when i backed up the front tire of the forklift flattened it down to about a 1/4 inch tall on one end! i figured the box was done for and we would just buy another case for the socket set but on of the other guys took and hammered the thing back into shape so well ya can hardly tell it was crushed. if its metal, i would try and straighten it before i replaced it
  6. #6
    Join Date
    Jan 2002
    Posts
    1,927
    Home-1+ acres New Hope, TX / 24 acres-Fannin County
    JD 950
    <font color="blue"> can't cost them more then $5 to make </font>
    On the surface, this often appears to be true. But working for a company that does manufacturing, I can tell you it cost far more than you would guess. Here is a typical scenario;
    An order is received for a widget
    Accounting records the order,
    Production dept generates work orders to build the widget,
    Purchasing dept orders the materials,
    Scheduling dept generates scheduling for manufacturing,
    Materials are received and inspected by incoming QC,
    Metal shop fabricates the part,
    QC inspection if necessary,
    Paint shop paints the part,
    QC final inspection,
    Part is received and stocked in warehouse,
    Part is pulled from warehouse for shipment,
    Shipping dept packages the widget,
    Accounting invoices the customer.
    Cost of part is a little material, a lot of labor, and (hopefully) some profit (unless there were some screwups along the way)
    And heaven help you if there is a drawing error. Then you move into engineering change order h*ll.
    In the "good ol days" I could walk out to the shop with a sketch on a piece of paper and have a part in a couple hours with just 2 people involved, me and the fabricator. Now there is a procedure and paperwork for everything.
  7. #7
    Join Date
    May 2001
    Posts
    1,333
    West PA
    ex-Bota Owner
    If I can get off for under a hundred, I'm usually relived. I give myself a few a year. Heck, I should budget for them! [img]/forums/images/graemlins/laugh.gif[/img]
  8. #8
    Veteran Member varmint's Avatar
    Join Date
    Mar 2003
    Posts
    2,404
    Northern Maryland
    Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
    I found a dandy little under-pickup seat craftsman toolbox at Sears- made from all-weather plastic, good catches, just the right size for some tools, and looks like it will last forever- $10. Seems to be waterproof, which is good. Pics if anyone wants them.
  9. #9
    Join Date
    Jul 2003
    Posts
    49
    Lynchburg, VA
    Kubota L4300 DX
    Well I was able to do as Mark said. I took it off and with a few well placed blows with a hammer and a block of wood, I was able to get it back to functional. Ain't perfect but the only time I'll see it is when I need another of those cheap lynch pins. You know, the ones that have the round wire on the top and pinch your fingers everytime you try to use them? Thanks again.
  10. #10
    Elite Member GerardC's Avatar
    Join Date
    Mar 2004
    Posts
    2,606
    New York
    KIOTI CK20 GEAR.
    </font><font color="blue" class="small">( Pics if anyone wants them.)</font>
    ALWAYS!!!!! G
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
